Hi guys. Where can i find a wind deflector for the sunroof for my E24 1987 model?
As you can see, it also fits a 3 series. https://www.realoem.com/bmw/enUS/par...&q=82119401098
Search the part # on Google or Bing, and I'm sure you'll find oneFor example https://www.autoaccessoriesgarage.co...ries?year=1987
good luck
Be careful. The car I bought several years ago had a wind deflector. I removed and eventually discarded it. Grit and sand, impossible to avoid if the car is driven, had gotten under the gasket along the front edge. That caused the paint to abrade. The only cure is to repaint the roof.
I preferred using the sunroof tilted upward at the rear rather than sliding open from the front.
E24: moved to a new caretaker
I have one of those on my 2002. It allows me to keep the car open a bit since I can't put rain / wind deflectors on it.
There is also 3M style stick on ones on eBay. Just measure the opening and go a little larger. That would be one way to solve the grit problem. My resolve is everytime the car gets a good bath, I just undo the 2 nuts and remove for the washing.
