Results 1 to 2 of 2
Thread: AC cabin fan problem
    Mar 2008
    Napa, Ca
    1987 M6
    Hello all,
    An odd problem has started happening in our 2006 530XI. The AC has been randomly switching from HI to LOW, and now it won't blow at HI speed when the AC is on. You can see the LED's change as you turn up the speed dial, but at about half speed, the fan won't go any faster. The lights keep changing up through the whole range, though.
    When we turn on the heater, then we get the full speed range on the fan, so I know it isn't the fan itself, or a resistor/circuit of a speed controller. It's like ONLY the AC funtion doesn't get to use full fan speed.
    I will add that we recently took the 530 in for service because of a passenger airbag seat mat error. The sensor mats have been known to fail, so BMW is replacing them free of charge for a full 15 years. However, we were told that a disconnected battery sensor cable is to blame for the error light. Replacement of that cable was quoted at $1500. That is crazy money, so I am ordering the cable for $275 from FCPEuro, and replacing myself. I suppose it's possible that could be causing the AC to freak out, but consider that highly unlikely.
    Has anyone seen this problem before?
    Thanks.
    Jose
    1987 M6
    Livin the dream!
    Feb 2010
    Atlantic Beach, Fl
    81,e21 orig ownr&05,e60
    Pull error codes on the IHKA module. May be a temperature sensor going out giving false reading, preventing logic circuited from allowing air handler to ramping up.
  1. AC / Aux fan problem
    By redlion2006 in forum 1996 - 2003 (E39)
    Last Post: 06-28-2014, 11:47 AM
  2. 318is- cabin fan problem
    By Arcticwarfare in forum 1991 - 1999 (E36)
    Last Post: 07-24-2013, 03:22 PM
  3. AC condensor fan problem
    By Tec Nine in forum 1996 - 2003 (E39)
    Last Post: 04-28-2010, 06:54 PM
  4. Cabin Fan problems
    By MadFish in forum 1999 - 2006 (E46)
    Last Post: 03-24-2005, 09:24 PM
  5. ac + blower fan problems
    By frankie2003 in forum 1983 - 1991 (E30)
    Last Post: 01-29-2004, 03:35 AM
