Results 1 to 3 of 3
Thread: M52B30 Turbo Piston Ring Gap Help
    Apr 2014
    Cardiff, UK
    E39 528i, E46 325ti
    Hi All, I'm in the process of starting to rebuild my m52b30 and just wanted to see what the recommended piston ring gap was for a turbo setup? I've got the ally euro block and I'm running stock m54b30 bottom end with oem rings etc. I'll be running a mls type head gasket which I think should see my compression around 9.0:1 maybe!
    Running an ebay Gt35 turbo and if possible I'd like to aim for about a bar of boost or around 350whp or more.
    Should I just go with the oem ring gap and leave the rings alone or should I be gapping them?
    Any advise would be great.
    Rob
    Mar 2012
    Renton, Wa
    98 m3
    Open the up a few thou.
    I have seen pretty large deviation in oem gap across cylinders. Open them all up to 18 thou or so and you’ll have less worries
    1989 535i - sold
    1999 Tiag/Dove M3 - sold
    1998 Turbo Arctic/black - current
    2004 TiAg/Black - Current
    PTE6870 | 1.15 ar | Hp Cover, Custom Divided T4 bottom-mount, 3.5" SS exhaust, Dual Turbosmart Compgates, Turbosmart Raceport BOV, 3.5" Treadstone Intercooler, 3.5" Vibrant resonator and muffler, Arp 2k Headstuds | Arp 2k Main studs | 87mm Je pistons | Eagle rods | 9.2:1 static compression, Ces 87mm cutring, Custom solid rear subframe bushings, Akg 85d diff bushings, 4 clutch 3.15 diff, , Poly engine mounts, UUC trans mounts W/ enforcers, 22RPD OBD2 Stock ECU id1700 E85 tune, 22RPD Big power Transmission swap w/ GS6-53
    Apr 2014
    Cardiff, UK
    E39 528i, E46 325ti
    Ok great, thanks very much for the help.
  1. Piston Ring gap.
    By dim22 in forum Forced Induction
    Last Post: 11-15-2010, 12:16 PM
  2. Lets talk piston ring gapping (specifically CP Pistons):
    By e34biturbo in forum Forced Induction
    Last Post: 02-27-2010, 12:21 PM
  3. Piston ring gap help - pros chime in
    By turnerNCM3 in forum Forced Induction
    Last Post: 06-25-2007, 05:22 PM
  4. Piston ring gap....
    By cosmos95m3 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-29-2007, 04:50 PM
  5. CP Piston Ring gap question
    By CosmoE36 in forum Forced Induction
    Last Post: 04-02-2007, 01:06 PM
