Results 1 to 11 of 11
Thread: Inner, outer fuel pump.
    May 2016
    Norwalk, ca
    1982 e21
    Time has come to replace both my fuel pump's. Any advice as where to purchase them? Looking for the one inside the tank and I believe it just needs the pump or do I do the hole swap not sure what I should purchase. And as far as the one under the gas tank I recently came across a post here on the forum through FCP EURO for $103.99 {BOSCH} but they did not have or I did not see the inner pump on their site. You guys have been very helpful over the years and thought I would post this so you can point me in the right direction. Thank's in advance.
    May 2005
    Red White and Blue
    82 E21
    You are correct, an OEM Bosch in-tank pump is not listed on FCP Euro's website and as far as I have seen not available from any other similar vendors. I have been keeping an eye out for a Bosch branded in-tank pump to keep as a spare but they are just not available. FCP and others do list the OE pump (pn: 16141179423) but it is ~$400!
    There are two aftermarket alternatives available at Rock Auto; AirTex and Spectra.
    https://www.rockauto.com/en/catalog/...assembly,10147
    I have no experience with either brand and feedback from various online sources is mixed. I am sure there are folks on this forum that can share their experiences.
    Just to complete the thread, here is the link to the main pressure pump:
    https://www.fcpeuro.com/products/aud...mp-bosch-69430
    MJ
    Dec 2017
    Jackson Mi
    E21, E30, E23
    I purchased the Bosch from FCP, it works great but the diameter was a little smaller so I had to wrap some rubber around it so it would fit snug in the bracket. I think the early and late model pumps were different but I'm not sure. I have both pumps for sale if it fits your car, mine is early. My in tank is original but it works. I looked at replacing it and found rock auto sells just the pump for a good price but not sure if anyone has tried this method.
    Sent from my SM-G955U using Tapatalk
    Dec 2017
    Jackson Mi
    E21, E30, E23
    Actually it looks like FCP has the pump listed as fitting both late and early. I'll PM you.
    May 2016
    Norwalk, ca
    1982 e21
    Thank's guy's for all your help.
    Nov 2007
    Sacramento, California
    1980 BMW 320i E21 M10B18
    Cool
    I'm using the AIRTEX E8196H with lifetime warranty from amazon, if it gives up the goat, Amazon(when they ship and sell) pays shipping to them and replaces with new and ships back at there cost, installed 9/ 2014.
    Randy
    May 2005
    Red White and Blue
    82 E21
    Quote Originally Posted by 320iAman View Post
    Randy
    Randy,
    Thanks for the follow-up. This is good info and makes me feel better about sourcing an Airtex pump as a spare.
    MJ
    Dec 2011
    Long Island, NY
    1980 320i 5 speed
    When my tank gets below 1/3 the main pump gets noisier so I suspect the in-tank pump might be weak or maybe just a clogged pick-up. On my last car I dropped the tanks and went through everything but I haven't tackled this one yet. I have more experience with Volvos which also use a dual pump system. Check out IPD. They have replacement tank pumps that might work on the bimmer.
    Nov 2007
    Cool
    Quote Originally Posted by mjweimer View Post
    Randy,
    MJ
    Sure
    Randy
    Vermont
    81 320i, 98 318ti
    Randy, is is a direct replacement or something needs to be modified to make it work? Based on the photos it looks like an aftermarket direct replacement which is great.
    Thank you,
    Max
    Nov 2007
    Cool
    Quote Originally Posted by mxl556 View Post
    Thank you,
    Max
    Direct Replacement - plug in,large o-ring, ect all the same except the looks, and the lifetime warranty
    Randy
  1. hissing outer fuel pump
    By cnowak1 in forum 1983 - 1991 (E30)
    Last Post: 03-31-2010, 11:14 AM
  2. Where can I buy a larger fuel pump for my 95 325i???
    By JustChillin in forum 1991 - 1999 (E36)
    Last Post: 11-16-2001, 03:22 PM
  3. Relocating Fuel pump
    By Guillermo in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 08-07-2001, 12:17 PM
  4. Need Instructions for fuel pump replacement please.
    By Jorge in forum 1991 - 1999 (E36)
    Last Post: 04-18-2001, 05:12 PM
  5. where can i get hi-flow injectors and fuel pump??
    By BJO in forum 1992 - 1999 M3 (E36)
    Last Post: 03-06-2001, 06:01 PM
