Results 1 to 6 of 6
Thread: Light control module
    Jul 2018
    Charlottesville, VA
    2000 BMW 323CI
    Before I possible waste time trouble shooting was wondering if someone has seen the following problem. I had a sudden problem in that the light warning panel lit with both headlights showing error. Working properly when parked got the error 20 minutes later when started. Headlights work fine and all lights I tried are working. Is this likely a problem with a connection or where to check first. Guess I better check the fuse to the LCM first but after that? Thanks for any help.
    Mar 2015
    west chicago il
    01 E46 330i 5sp man spor
    Check the front turn signal sockets. They burn the center contact. The bulb indicator is for any bulb on the corner of the car not just headlights.
    Quote Originally Posted by JIM K4CGY View Post
    Sent from my SAMSUNG-SM-G870A using Tapatalk
    Jul 2018
    Charlottesville, VA
    2000 BMW 323CI
    Quote Originally Posted by randy72877 View Post
    I'll check them tomorrow. I just checked the lights and all burn normally.
    Sep 2012
    El Paso Del Norte, TX, US
    ‘15 F31d Msport
    That happened to me a couple of times. I think it was corrosion or oil on my city light bulb’s. Took em out, wiped em down, and put them back in. No issues for the last year.
    If I were to give my Touring a first name, I'd probably name it "Alan".
    Mostly because I like puns.
    Mutual Admiration Society #5
    Jul 2018
    Charlottesville, VA
    2000 BMW 323CI
    Light panel showing both headlights out.
    I found the problem and likely you won't believe it--well I guess you might. The problem was both license plate lights were out due to a broken wire at the flex point of the harness between the car body and trunk lid. Why license lights showed up as headlights is the big question. As they were the lights that were out of vision in daylight and out of mind (what little I have left) were found during the annual car inspection. Thanks for everyone's help.
    Jim
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Yup, that’s a common problen in the E46.
  1. help with Light Control Module LKM
    By Carcrazy in forum 1996 - 2003 (E39)
    Last Post: 01-23-2006, 08:43 PM
  2. Light Control Module Location? Help!
    By DIMIRO in forum 1988 - 1994 (E32)
    Last Post: 01-20-2006, 06:40 PM
  3. WTS e39 Light Control Module (LKM/LCM) NEW
    By mchad in forum BMW Parts Wanted
    Last Post: 01-06-2006, 01:22 PM
  4. 97 e39 light control module headache.. Help?
    By mchad in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-30-2005, 10:21 AM
  5. Light Control Module Software Updated
    By Kevlar in forum 2001 - 2006 M3 (E46)
    Last Post: 08-26-2003, 12:48 AM
