so i had my 1jz gte from mk3 with JZA-70 ECU and i'm searching for someone (That did the swap before) to confirm me with the wires i found i had to connect with the x20 and if there are any missing wires or anything wrong with what i found
here's what i found:
RPM:
toyota (17 and 23 in X )
bmw black pin 20
SPEED :
toyota ( 8 in T )
bmw black and white pin 14
WATER TEMP SENSOR:
toyota ( 4 in W )
bmw brown and violet pin 11 or 12 x20
OIL TEMP SENSOR:
toyota (....????
bmw brown and green pin 23
FUEL PUMP:
toyota (16 in X )
bmw green and violet pin 13
STARTER RELAY:
toyota ( 11 in T )
bmw black and green pin 15
STARTER IGNITON:
toyota ( 13 in T )
bmw black and yellow pin 18
O2 SENSOR HEATER POWER:
toyota ( 1 in X )
bmw green and white pin 22
ALTERNATOR:
toyota (....????
bmw blue pin 25
CHECK ENGINE:
toyota ( 4 in T )
bmw gray pin 8
DIG:
toyota (15 in X )
bmw white and voilet pin 17
REVERSE LIGHT:
toyota ( 5 in T )
bmw pin 10
BATTERY TO ECU SWITCHED:
toyota ( 1 and 12 in T )
bmw green 21
