Results 1 to 3 of 3
Thread: Random Misfire
    Dec 2011
    philippine
    e36 318is
    Random Misfire
    hi guys,
    i need you help, 3 years ago i have swap my 318is engine to s52 with automatic transmission, the problem was i have been experiencing random misfire at above 6k rpm, at first it went away after i changed my spark plugs, but after i change my intake manifold to schricks the misfire didnt went away. i also tried using the recalled crankshaft sensor but it became worse since it misfired and hard started, btw my crankshaft sensor is located in the front after i used the adapter lead with the back sensor the car misfired even low rpm. i need help guys,
    these are my mods:
    AFE intake
    Schrick intake manifold
    ebay headers with full 2.5 inch stainless tube and dinan catback (cat deleted)
    the parts i have changed for misfire issue:
    6 ignition coils
    6 spark plugs (NGK)
    crankshaft sensor
    camshaft sensor
    02 sensors
    Elkridge, Maryland
    1997 M3/4, 2003 540i
    Check the rubber boot connecting the airfilter to the intake for leaks. I had a similar issue and found a slit in the rubber boot. Replaced this boot and problem went away.
    Dec 2013
    Chicagoland area
    EXOTICS
    Remove rubber intake boot,
    squeeze and carefully inspect all areas,
    the cracks that were once hidden will appear.
  1. Multiple/Random Misfire Codes
    By HolE39 in forum 1992 - 1999 M3 (E36)
    Last Post: 05-08-2011, 08:12 PM
  2. Random Misfire,fuel cut off,start up Help!!!!
    By 1gatonocturno in forum 1999 - 2006 (E46)
    Last Post: 08-25-2009, 07:04 PM
  3. Random misfire at idle, PLEASE HELP!!
    By bigmitch117 in forum 1992 - 1999 M3 (E36)
    Last Post: 06-28-2008, 09:25 PM
  4. Random misfire.... Update and solicitation....
    By TouringDan in forum 1988 - 1996 (E34)
    Last Post: 06-22-2007, 07:55 PM
  5. Need Help With Random Misfire Code
    By nh68 in forum 1999 - 2006 (E46)
    Last Post: 09-06-2005, 11:47 PM
