Results 1 to 2 of 2
    Jul 2018
    Hong Kong
    2015 BMW X6
    2015 X6 interior door trim question
    Hi guys,
    As you can see in the picture, the door trim is damaged and I am trying to get a replacement part.
    However, I am not sure what is part is called. Can anyone please help?
    Thanks in advance.
    https://imgur.com/EpWTWtC
    (northeast) Indiana
    15 650ix GC & 14 X5 50i
    If you want us to look up parts for you...the last 7 digits of your VIN would have REALLY been helpful just in case there may be some slightl differences due to model differtiations. But door panels are usually much the same. I'm going to also assume that you are RHD and this is the front passenger door panel? I generically selected a 2015 f16 X6 35i.
    If you're not familiar with the multiple online part databases...copy and save the links below...they are invaluable when needing to know info as you've inquired about...especially when ordering parts. Once you have the 11 digit BMW part number...then shop using that number. For example, you can usually type "BMW xx xx x xxx xxx" (where x=BMW part number) into a google search box...and you will usually find vendors selling that part if it's available. If not, you may need to inquire at a BMW dealership's parts department if the part is obscure:
    1. https://www.realoem.com/bmw/enUS/select
    2. http://bmwfans.info/parts-catalog/
    3. https://www.etkbmw.com
    Click the link above the diagram below and scroll down the part number index (for #1) until you see the type of finish you have in the supplemental column (one of the types of aluminum trim). Then use the 11 digit BMW part number for whichever one you need (left/right?). BTW, left/right is determined by the position of the driver behind the steering wheel. It also appears that there are listings based on the audio system you have (Harmon Kardon or B&O)...which isn't visible in the pic you posted...so keep scrolling down to the correct part number based on the info in the supplemental column:
    {TIP: encircled numbers in the diagram/illustration refer to hardware}
    http://bmwfans.info/parts-catalog/F1...r_panel_front/
  1. Door trim question.
    By draccent in forum 1983 - 1991 (E30)
    Last Post: 04-10-2008, 06:07 PM
  2. WTB: interior door trim for e36 coupe
    By ilanham in forum BMW Parts Wanted
    Last Post: 04-20-2007, 06:26 PM
  3. Reconnecting interior door trim?
    By Strahan in forum 1995 - 2001 (E38)
    Last Post: 07-31-2006, 05:05 PM
  4. WTB ddriver side interior door trim, window motor for m3
    By boostin7 in forum BMW Parts Wanted
    Last Post: 06-07-2006, 06:08 AM
  5. 323ci - Falling Interior Door Trim
    By mcalimli in forum 1999 - 2006 (E46)
    Last Post: 03-26-2006, 03:44 PM
