Results 1 to 3 of 3
    Mar 2008
    Northern NJ
    2013 X5 35iXdrive
    Console USB charging
    I’m looking for some info on the USB port in the center console. Does anyone know if it provides charging capabilities? If so, what’s the voltage? I end up drawing the battery down even when it’s connected. If I use my cigarette lighter adapter, I don’t have that problem.
    Is it possible I have a blown fuse or other voltage problem?
    Thanks!
    If winning isn't everything, then why keep score?
    There are many parts of my youth that I'm not proud of. There were..... loose threads - untidy parts of me that I would like to remove. But when I... pulled on one of those threads - it'd unravel the tapestry of my life
    (northeast) Indiana
    15 650ix GC & 14 X5 50i
    You don't say what your device is (apple/android?)...but some brands have higher power requirements than others. If you have a nav/entertainment/communication booklet...you may want to check to see if the e70 is different than the info below which is from a 2013 f06/f12/f13 (6 series) nav/entertainment/communication booklet. You may need to get a snap in module which will charge as well as connect the device to the vehicle.
    Mar 2008
    Northern NJ
    2013 X5 35iXdrive
    Quote Originally Posted by Qsilver7 View Post
    Quicksilver: thanks for the response. Sorry for neglecting to point out the info. I have an iPhone 6s e
  1. Installed a USB charge port in a blank switch plate
    By Mr Bingley in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 08-17-2015, 11:46 PM
  2. Custom USB Charging point for E36
    By lambertius in forum 1991 - 1999 (E36)
    Last Post: 04-05-2014, 01:57 AM
  3. 2007 E70 Center console USB help
    By NOYGDB in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 12-11-2011, 09:50 PM
  4. ▀▄ eas | DICE SILVERLINE iPod Integration Kits available for BMW - USB Charge Support
    By tom @ eas in forum Group Purchases & Supporting Vendor Specials presented by eBay
    Last Post: 02-16-2009, 12:40 PM
  5. does USB charge Ipod?!?!
    By slaveofChrist in forum Photography & Multi Media
    Last Post: 06-30-2005, 04:21 AM
