Results 1 to 11 of 11
Thread: ALPINA B7 Supercharger
    Dec 2007
    Dallas, TX
    '93 850Ci- Daily Driver
    If your SC is leaking oil, it is quite easy to replace the seals (if the impeller does not have the "wobble" to it yet). Just received a seal kit from a fellow forum member on the "other" forum (nervnom3) and started the process last night.
    First step is to disassemble the blower housing, and everything went as planned, until I took out all of the bolts, this is where it came to a screeching halt!
    Okay people, I am going to vent a bit here because it seems that the previous owner of my B7 decided that a few tubes worth of PERRMATEX are far superior to replacing the O-rings that actually prevent the oil from leaking. It is all good until sometime in the very near future that sealant fails, and you have to disassemble everything that has been GLUED together!! It took a few hours just to get the two halves separated, another 3 hours to carefully remove all of the sealant and clean everything (use a very soft plastic scrapper to prevent damaging the sealing surfaces), and about 30 minutes to finish cleaning everything in preparation for reassembly.
    When you go to put everything back together, make sure there is a slight coating of motor oil on all of the rotating parts, and do not attach the SC serpentine belts until you have started the car and the oil has had a chance to circulate up into the Supercharger.
    Looking kind of worn, even from the outside:
    That was all, carry on....
    '93 850Ci - Mineralweiß Metallic
    2001 740iL - Titansilber
    ALPINA B7 -Alpinweiß III
    Jul 2014
    Westfield, IN
    '91 e31 M70
    Thanks for the post! How did you determine the seals needed replaced? I assume it was leaking?
    '07 e65|N62 - Alpina B7 - Black Sapphire|Black|Loaded|GONE
    '02 e46|M54 - Orient Blue|Beige|'Vert|GONE
    '00 e39|M52 - Anthrazit Metallic|Grey|GONE
    '01 e38|M73 - Anthrazit Metallic|Schwarz|Shadow-Line|GONE
    '91 e31|M70 - Schwarz|Schwarz|M70|FOR SALE
    '13 328i Auto - Black Sapphire|Coral Red|Sport Line|GONE
    '05 545i SMG - Jet Black|Black|Bamboo Anthracite|GONE
    '07 335i Auto - Montego Blue|Grey|GONE
    '05 545i SMG - (Euro Delivery 7/22/05)|Black Sapphire|Auburn|GONE
    '97 528i Auto - GONE
    Dec 2007
    Dallas, TX
    The quickest way to verify that oil consumption is from leaking SC seals, is to pull the rubber boot off the lower intercooler port, if oil runs out, you have leaking seals. Every single seal was hard as a rock on mine, but now everything is wonderful again. It really is not that difficult if you have some mechanical skills and work in an orderly fashion. Looks brand new now and will be installed first thing in the morning.
    02B9F392-0348-47E5-A6F1-41C976A50B6B.jpg C2E08546-39C8-436C-94F8-19D993783A22.jpg
    Jul 2014
    Westfield, IN
    '91 e31 M70
    She’s a work of art! Mine only has 50k and installed the lower temp thermostat. I hope that help with longevity, but given the RPMs and heat, it’s just a matter of time.
    Still my favorite BMW I’ve ever owned though... although my 850 M73 swap is almost done! , so we’ll see after that!
    Dec 2007
    Dallas, TX
    These seals really should be replaced as part of a preventative maintenance cycle every 60k-70k miles...
    Atlanta, Ga
    Alpina B7/4.6is/E34 540
    Looks fantastic. Were you seeing any external smoke?
    Does your B7 have the odd, laggy throttle that many seem so be plagued with? Just a characteristic of the beast? No B7 owners to can quiery local to me.
    Vancouver Washington
    2004 BMW 760 Li 1991ZR1
    Hi,
    At least you are touching your BMW & Not taking it to the dealer.
    Manfred E.........
    2004 760LI
    Dec 2007
    Dallas, TX
    Quote Originally Posted by imola38 View Post
    Not really, when I first got the car, I was amazed at the snappy response. When I pulled the Supercharger and did the seals and general cleaning, I found 3 shop towels lodged in the intercooler intake that the last "mechanic" forgot, so I was completely thrilled again since the car is much quicker now.
    Dec 2007
    Dallas, TX
    Quote Originally Posted by Tomcat 74 View Post
    Hi,
    Manfred E.........
    2004 760LI
    I did take it by the dealer for a misfire diagnosis (didn't throw a code, but you could tell it wasn't 100%). Dealer came back with: 1."replace plugs and coils" (I put new plugs and coils in less than 1200 miles before). 2."Alternator bracket leaking" (I just finished that job a few weeks earlier - the oil was from a loose SC intake boot and the failed SC Seals), 3. "engine mount needs replacing" (okay, that was on my list to do, and I did just complete that), 4. "fix leaking SC oil supply line" (wasn't leaking - see #2 above), 5. "replace front lower control arms" (also on my to-do list - parts were already in the garage and was just completed last weekend).
    The quoted price for all the dealer "fixes" came to $12,015 after tax. I spent less than $350 for seals, arms and engine mounts.
    This is why I do my own work...
    Jan 2012
    Upstate South Carolina
    1996 840Ci / 2007 B7
    Just posted an impeller solution in another thread. Much cheaper than a new SC. Let me know if you can't find it
    Mar 2019
    Budapest
    BMW 545 supercharged
    Hi Guys,
    I'd like to just highlight your attention that there's a cheaper solution than buying a new supercharger for the leaking supercharger issue. Just contact TheCrazyDIYengineer. You can find it on this link: www.thecrazydiyengineer.com
  1. Alpina B7 Supercharger backpressure noise?
    By MontanaRob in forum 2002 - 2008 (E65, E66)
    Last Post: 01-24-2019, 04:00 PM
  2. Alpina B7 Supercharger backpressure noise?
    By MontanaRob in forum Forced Induction
    Last Post: 08-26-2015, 07:22 PM
  3. Alpina B7 supercharger noise?
    Last Post: 11-03-2014, 06:06 PM
  4. E65,E66 Alpina B7 supercharger USED but works
    By landyacht06 in forum Forced & Chemical Induction Parts
    Last Post: 02-19-2013, 09:17 PM
  5. 2006 BMW Alpina B7 Supercharged 7-Series Coming this Summer
    By 740iLHI in forum 1995 - 2001 (E38)
    Last Post: 08-09-2006, 11:44 AM
