Results 1 to 10 of 10
Thread: 328d X-Drive Strange New Sound lifting throttle
    Nov 2014
    All, I have a 2014 328D X-Drive with 112k miles on it. Just put some new Continental tires on today as the old tires I had were cupped quite a bit. After putting the tires on we went for a spin on the highway and everything was nice and quiet until I decided to let off the throttle. I initially thought I had a wheel bearing going out, but I think I ruled that out by putting it in Eco Mode and free wheeling on throttle lift. Noise was not present and tires are perfectly quiet.
    It almost sounds as if I have a faint Jake Brake noise on the diesel. Is the Eco Mode test legit? Steering changes doesn’t seem to reflect, or have any feel of a bad wheel bearing or one going out.
    I did put a new air filter into the car the other day, I reinspected the clamps and everything looks normal there, I guess i can look again but everything seems fine with hoses and other lines.
    Jul 2004
    Houston, TX
    36 Cylinders
    Hope it's not transfer case output flange.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Nov 2014
    I’m still on the fence that it could be a wheel bearing. As this is an X-drive is there a simple way to test that wheel? It is the front right
    Nov 2014
    That is if it is a wheel bearing
    Jul 2004
    Houston, TX
    36 Cylinders
    Ah, you can hear it on the front?
    I would stop immediately and inspect, make sure bolts are all on and tight!!
    -Abel
    Nov 2014
    You know, that thought did cross my mind
    Jul 2004
    Houston, TX
    36 Cylinders
    Also inspect behind the wheel, to make sure you're not dragging something.
    -Abel
    Nov 2014
    It has happened to me in the past one other time
    Nov 2014
    All, I have pretty much determined that I have a bad front right wheel bearing on the X-Drive, has anyone done one as of yet? If so, what all is involved and will I need any specialty tools to get it out? It appears that besides the new wheel bearing, I will need a few attachment bolts that are one use (stretch issues), and a new bolt with a spring assembly in it, I presume this goes into the axle, but I have not looked at anything in detail at the moment as I have not taken it apart.
    2005 330ci ZHP 6MT
    2005 330i ZHP AT (Sold)
    1989 325i
    1990 318is
    2014 328d X-drive
    2017 VW Alltrack
    Jul 2004
    Houston, TX
    36 Cylinders
    Looks fairly simple. Remove caliper and rotor, disconnect axle, then the bearing hub comes off from the main hub. Doesn't look like any pullers are involved.
    You should put a new axle bolt and new bearing bolts.
    -Abel
  1. Strange (New) engine/exhaust sound boggle!
    By Zchild in forum 1996 - 2003 (E39)
    Last Post: 06-19-2018, 11:15 AM
  2. Strange new sound after alternator install and coolant change.
    By Raudi Driver in forum 1995 - 2001 (E38)
    Last Post: 03-16-2013, 01:57 PM
  3. Replies: 9
    Last Post: 07-11-2011, 12:37 AM
  4. Strange whiny sound when I rev after hard braking/driving
    By m3beemer16 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-11-2008, 03:35 AM
  5. Strange "cracking" sound when first driving...
    By ben8jam in forum 1999 - 2006 (E46)
    Last Post: 03-23-2007, 06:28 PM
