Results 1 to 13 of 13
Thread: E23 auto transmissions
    Dec 2017
    Jackson Mi
    E21, E30, E23
    Looking for a little more info on the automatic transmission usage on the e23. In the US from what I understand it was a 3 speed until 83 then went to a 4 speed. What year did it upgrade to electronic?
    Sent from my SM-G955U using Tapatalk
    Jun 2010
    TX
    1983/84/85 745i
    Thumbs up
    745i received it 05/83 with the introduction of the 3.4L Turbo Motronic.
    US spec cars? Early 1985 production, probably for late summer launch. I do not have exact month and year for you.
    I make E23 parts.
    10/1984 745i
    11/1984 745i
    11/1984 735i (10:1-265/6)
    Hamburg, NY USA
    e23, e32, e34, e39
    My US 4/85 came with the non EH. My 5/86 (titled as an 87) had it.
    Dec 2017
    Jackson Mi
    E21, E30, E23
    Anyone have a working 4 speed non EH they want to sell?
    Jun 2010
    TX
    1983/84/85 745i
    Thumbs up
    Quote Originally Posted by Scottr09 View Post
    What is not working on yours?
    I would not trust a 35 year old transmission in my car. The difference in shift quality between a reman and used is day and night. Those internal seals are comically dried out and rock hard.
    I make E23 parts.
    10/1984 745i
    11/1984 745i
    Dec 2017
    Jackson Mi
    E21, E30, E23
    I pulled it out and was going to swap it with another 4hp22 I had but the output shaft and flange were different. Mine would not start in drive unless I put it into first gear then it would shift fine once moving. I was hoping to find a better candidate for a rebuild or something to at least get me going through the summer.
    Jun 2010
    TX
    1983/84/85 745i
    Thumbs up
    Some had Ujoints and some flex disc...you sure the output shafts are different? I put a 4HP24 V12 output in my 4HP22 as it is thicker and has an additional oil feed for cooling.
    I make E23 parts.
    10/1984 745i
    11/1984 745i
    Dec 2017
    Jackson Mi
    E21, E30, E23
    Update: I found a parts car sitting in the weeds in northern Michigan. It's an 85, mine is 84, I got it home and pulled the trans. It all looks like it will bolt up but I will also use the parts cars driveshaft. It has the u joint mine had the flex disc.
    Jun 2010
    TX
    1983/84/85 745i
    Front half of the shafts is the different point. You can just toss it all in and go... I would not toss in a 35 year old trans, but that is me.
    I make E23 parts.
    10/1984 745i
    11/1984 745i
    Aug 2018
    Chicago, IL, USA
    '85 735i, '75 CS
    Scottr09, you mentioned parts car - can you "part" with one ABS wheel sensor?
    May 2013
    Killingworth, CT
    '84 733i, 01 X5 00 750iL
    I am getting a running, driving 84 733i which has the non EH 4 speed auto. Car will be here in a couple weeks. The trans will be available - it is getting manual swapped using parts from my other e23 that will become a parts car. If the trans you sourced does not work out let me know.
    Steve H.
    Dec 2017
    Jackson Mi
    E21, E30, E23
    Quote Originally Posted by coupesport View Post
    Way to sneak that in here! I will send you a PM when I get back in town with the parts car. Are they the same all the way around? If so I will have 4 available.
    Dec 2017
    Jackson Mi
    E21, E30, E23
    Quote Originally Posted by BONDOSPECIAL View Post
    It is up and driving! Thanks for the offer I'll keep this in mind if I run into any issues.
  1. Swap auto transmission to standard
    By viper200202 in forum 1983 - 1991 (E30)
    Last Post: 09-11-2002, 01:46 PM
  2. Auto Transmission in 1999 M3?
    By NotConvicted in forum 1992 - 1999 M3 (E36)
    Last Post: 08-15-2002, 09:23 PM
  3. auto transmission not catching!...what do you think?
    By pete1787 in forum 1991 - 1999 (E36)
    Last Post: 06-11-2002, 02:24 AM
  4. auto transmission modes
    By latis21 in forum 1991 - 1999 (E36)
    Last Post: 05-09-2002, 06:20 PM
  5. Auto transmission problems(please help)
    By NWG in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-17-2002, 10:38 AM
