Can an auto M70 EML be used / converted for use in a 6 speed car?
Regards,
Brian
Cave Creek, AZ
Yes just change the chip and adjust the accelerator pedal stop screw as per the manual.
Omega Man, Thank you for the insight, I will check out the manual for details on the pedal adjustment, is the chip also the known as the EML chip?
Regards,
Brian
Cave Creek, AZ
Yes if you buy a cheap eprom programmer you can burn the chip yourself.
https://www.ebay.com/itm/New-Genius-...wAAOSw3xJVXpdv
Then you need a chip which is a 27256 eprom like this
https://www.ebay.com/itm/HITACHI-HN2...EAAMXQOT5Q~RPQ
Once you have those two items I can email you the manual EML file to burn into the chip.
https://www.bimmerforums.com/forum/s...l+pedal+adjust
If you read from around page 8 onwards it should shed some light on the pedal adjustment.
Chips ordered sir, will keep you posted!
Thank you again for this valuable information
Regards,
Brian
Cave Creek, AZ
