I've never owned a convertible, and was wondering what others hear use to clean thier convertible top as well as something to sort of polish out the back plastic window. The window has some hazing to it, which I've read is normal, is there a good product to use to help reduce this and keep it at bay?
I will also post in Z3 section...
usually any type of wax will clear up your plastic window pretty good.
Wax????!! Use a plastic polish and cleaner, ie Plexus or Novus. As for the vert cover, use rag-topp or the porsche brand cleaner.
Yes wax, I've used it on tons of older rag-top plastic windows and work great.
I wold suggest a product called Ragg Topp for Fabric or Ragg Topp for Vinyl for the convertible top and The Scratch Off System for the plastic window.Originally Posted by 350ztn
Scratch Off is a relativelt new product. The Scratch-Off System is the ultimate in plastic, Lexan, Plexiglass and acrylic surface restoration. Are your headlights hazy? Is the vinyl back window of your convertible top scratched and yellowing? If so, Scratch Off is the tool for bringing them back to like-new condition. The system uses a series of foam pads and specially formulated abrasive polishes to smooth, even and deep clean old or damaged plastics. The pads mount to an included backing plate which fits most drills. The process is slow, so be patient. It may take several minutes to work a small section.
Good Luck,
David
I purchased the meguires kit #10 and #17 I think, I'm hoping this works since it was $20, if not where can I find more info on this scratch off system your talking about dternst
