Results 1 to 17 of 17
Thread: 540 V8 ticking only at low speed
    May 2018
    Rockford
    Notice slight ticking just as I begin accelerating and it goes away at about 20mph...oil level is correct, just changed. Just got the car, and drove it only once so don't know if it was there all along. 190k miles, very well kept.
    San Jose, CA
    1997 BMW 540i 6 speed
    Check the oil pressure. S/b about 50 psi at 1000 RPM.
    Have the chain guides been replaced? If not, they are overdue. They typically last circa 150k.
    Try replacing the chain tensioner.
    May 2018
    Rockford
    No idea, just bought it...
    Jul 2011
    hillsborough n j
    2001 540i sport 6spd
    Check for baseball cards in the spokes. If you find a Honus Wagner it’s mine
    Santa Cruz Mountains
    '03 M-Sport 540iA
    Kinda common noise...probably related to the coils if you mostly hear it at idle and low speed. Mine was...there's a video of the difference posted somewhere in the archives.
    '00 540iA Sport w/235k+ Original TCG's, Vanos and transmission.​*Trans failure at 244k+...FS Now
    West of Boston, MA
    2001 BMW 540iT/6
    Coils? Do tell....
    '03 M-Sport 540iA
    Found the links...
    BEFORE:
    AFTER:
    Not perfect but WAAAAAY better IMHO...
    Feb 2009
    Sweden
    '96 540i S/C
    And it's not just the hydraulic lifters ticking? Mine ticks like a diesel every spring. 3x2min at 3000rpm idle (Actually a TIS procedure) and it's smooth as silk.
    [E39 540i] - with S/C ESS kit (plus some upgrades)
    [E34 540iA] - Gone
    May 2018
    Rockford
    It does NOT make any sound sitting idling, even when I rev it pretty high. Only happens < 40mph...Prior put in new coils and plugs, I was told, haven't spoke to him but his dad mentioned it. Makes me worry. Fresh oil change, 0/40 synthetic. No low oil pressure light.
    What is 'the tin man'?
    I may double check all spark plugs for looseness but why no sound at idle or revving?
    San Jose, CA
    Quote Originally Posted by Eriklane View Post
    I'm confused: You state that it does not make any sound, but the video clearly shows a noise.
    Compare your symptoms here: http://www.beisansystems.com/procedu..._procedure.htm
    Mar 2018
    ct
    540 m sport
    Probably vanos.
    San Jose, CA
    That would be my guess, too.
    May 2018
    Rockford
    I have no vanos. Funny I was reading other posts people saying 1/2 quart extra oil fixes it. I did notice it tonight when the car was warm. I put in a quart of Lucas oil stabilizer, no change. Using Amsoil Euro 0-40. Have checked oil pump, tight. With summer temps in MI in the am, can't imagine why lifters would tick.
    May 2018
    Rockford
    I will find out about the chain tensioner, funny I just had that apart doing the upper timing cover gaskets...
    Sep 2013
    Tx.
    02 bmw 540
    Quote Originally Posted by topaz540i View Post
    Ahhhhh, good Ol’ Peter Wagner! I’d prefer Babe Ruth.
    May 2018
    Rockford
    Somehow someone thought those videos were mine, those are a bmw with vanos, I don't have it. Going to get under and check the tin covers and look for anything that I can that might be rattling. I have to say it sounds like lifters, and it does do it when warm and cold, but not always. Will look around, but have to talk to the prior owner if he replaced the tensioners, haven't done that yet...
    May 2018
    Rockford
    Have not taken out the chain tensioner, may do that this week and make sure it's clean, but doubt issues, oil pan off and it was very clean so doubtful motor is gunky. Did some testing. Both rear wheels up, in drive, no clicking. Turned Traction control off, same. Tried with one wheel up and other down, swapped, nothing. so it appears nothing in the rear wheels is the cause. Today at low speed it ticked, I tossed it in neutral, kept revs the same, tick stayed. So possibly not trans?
    Do need to try front wheels up and spinning but likely can't spin fast enough.
  1. 540 bucks and jerks at low speeds
    By vtr1000 in forum 1996 - 2003 (E39)
    Last Post: 02-15-2010, 09:22 AM
  2. 540i/6 ticking Noise at low speed
    By larinah in forum 1996 - 2003 (E39)
    Last Post: 05-03-2009, 07:15 PM
  3. Strange sound at low speeds under throttle.
    By Gop-Dogg in forum 1992 - 1999 M3 (E36)
    Last Post: 04-10-2006, 01:06 AM
  4. Brake chirp at low speeds withOUT applying brakes
    By hccyong in forum 1992 - 1999 M3 (E36)
    Last Post: 03-26-2003, 01:36 AM
  5. Hissing noise at low speeds
    By RightM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 08-23-2001, 01:52 AM
