Results 1 to 5 of 5
Thread: Newly help please
    Jun 2018
    Pennsylvania
    2006 BMW 750i
    Newly help please
    Just bought my first bmw, 2006 bmw 750i. The previous owner told me it needs cats and 02 sensors that's it. Plugs,coil packs been changed. I took it for a test drive, under load no power at all. Flat surface I step hard on the has no power at all dies on its face. I checked the codes, the 2 rear 02 sensors were on there and misfire in cylinder 1. Brand new plug and brand new coil on all 8. Could the gutted cats do this? I had cars before with gutted cats and they ran ok even with 02 sensors going out. Thank you and advice is greatly appreciated
    Dec 2013
    Chicagoland area
    EXOTICS
    Are you sure the cats are gutted,
    and not actually clogged?
    A diagnostic scan would be recommended.
    Jun 2018
    Pennsylvania
    2006 BMW 750i
    Cats are gutted
    Dec 2013
    Chicagoland area
    EXOTICS
    Clear codes and perform new scan,
    but I suspect fuel delivery issues.
    Install a FPG at fuel rail,
    with a hose long enough for the gauge to be taped,
    and viewable from the windshield.
    This way you are able to view and record values while symptoms occur.
    Jun 2018
    Pennsylvania
    2006 BMW 750i
    I performed scan, no new codes. But still acts up same way. I started and it acted up on start up, cleared up but when under heavy acceleration falls on face
  1. Problem with my '97 328i help Please!!
    By Sean~328i//EastBay in forum 1991 - 1999 (E36)
    Last Post: 05-24-2003, 12:47 AM
  2. Suspension help please...'97 M3, 37K, bought used>
    By jayhudson in forum 1992 - 1999 M3 (E36)
    Last Post: 05-29-2001, 03:27 PM
  3. Busted shock mounts! Help Please!
    By Gluall@aol.com in forum 1992 - 1999 M3 (E36)
    Last Post: 05-22-2001, 07:05 PM
  4. vibration on braking, some help please...
    By joeyc in forum 1991 - 1999 (E36)
    Last Post: 04-19-2001, 02:05 PM
  5. Need Help, Please Read!!!!!!!!!
    By MMTuning in forum 1992 - 1999 M3 (E36)
    Last Post: 03-31-2001, 06:42 AM
