Results 1 to 14 of 14
Thread: Winkfp Error 209
    May 2018
    Chicago,IL. USA
    2006 BMW 750i
    Winkfp Error 209
    Hello this is my first post any help surely will be appreciated. About a week ago now I was flashing my SVS in my 2006 BMW 750i with WinKFP about 50% complete I bumped the ICOM Chord and disconnected it from the OBD. Now I can't flash the SVS. I had a battery charger connected and all that everything hooks up but I can't flash the SVS. It is giving me an error of "Error 209 UIF Cannot be read" here are some of the screen shots.
    Jul 2004
    Houston, TX
    36 Cylinders
    I would try turning off UIF in comfort mode in configuration, and force flash a correct ZUSB.
    That, or expert mode.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    May 2018
    Chicago,IL. USA
    2006 BMW 750i
    Ok I will give that a shot but if you are available how exactly doo I turn off UIF in WinKFP?
    Jul 2004
    Houston, TX
    36 Cylinders
    Click configuration menu on top, and uncheck UIF for Comfort mode.
    After you flash it, if successful, you may try to flash it again with UIF on again, to populate that area correctly. Never had a failure like this, but that's what I would do.
    There's another way to overwrite the UIF in tool32 in some modules. It's available for SVS_E65.prg, aif_schreiben job. But you have to know the correct argument format to put in.
    -Abel
    May 2018
    Chicago,IL. USA
    2006 BMW 750i
    if you have any information on how to with tool32 please let me know I will try your first suggestion now
    Jul 2004
    Houston, TX
    36 Cylinders
    the "Job-Info" window will guide how to generate a new UIF (aka AIF)
    It would be a great help to you if you had a save of the identification field for the SVS from before. Then the UIF field repair becomes easy.
    But since the flash is corrupted inside the SVS, it still needs a complete flash first.
    I would also try ISTA-P, but that has a tendency on making things worse, or giving the great recommendation to exchange part....
    -Abel
    May 2018
    Chicago,IL. USA
    2006 BMW 750i
    I have the hardware number because before I have anything I take a printout of the UIF and Errors
    May 2018
    Chicago,IL. USA
    2006 BMW 750i
    cp1error.JPGUnfortunate the same error I will now try tool32
    May 2018
    Chicago,IL. USA
    2006 BMW 750i
    Looks Like the problem is with Error Size UIF. How to reset this would help especially stepping procedure cp3tool32.JPG
    Jul 2004
    Houston, TX
    36 Cylinders
    You need to be using the aif_schreiben job to write a new aif in. It's a bit more advanced of a procedure.
    You can't 'reset' it because there's corrupted data in your module from abrupt disconnect during flash.
    -Abel
    May 2018
    Chicago,IL. USA
    2006 BMW 750i
    NCS, NCS Dummy, WinKFP and INPA , I really get on how to code and diagnosis issues. But I must admit Tool32 I'm having a hard time understanding but I will try to run your suggestion when I get home on today. The Argument and execution is what I am having an issue with.
    Jul 2004
    Houston, TX
    36 Cylinders
    aif_schreiben Job arguments needed:
    Argument 1: AIF_FG_NR
    type: string
    comment: VIN
    7-digit or 17-digit
    Argument 2: AIF_DATE
    type: string
    comment: Date of SG programming
    in the form DD.MM.JJJJ or DDMMYY
    Argument 3: AIF_ZB_NR
    type: string
    comment: BMW / Rover assembly number
    Argument 4: AIF_SW_NR
    type: string
    comment: BMW / Rover record number - software number
    Argument 5: AIF_BEHOERDEN_NR
    type: string
    comment: BMW / Rover authority number
    Argument 6: AIF_HAENDLER_NR
    type: string
    comment: dealer number
    Argument 7: AIF_SERIEN_NR
    type: string
    comment: Tester serial number
    Argument 8: AIF_KM
    type: long
    comment: km-level during programming
    Argument 9: AIF_PROG_NR
    type: string
    comment: program number
    Each argument needs to be separated by ";"
    -Abel
    May 2018
    Chicago,IL. USA
    2006 BMW 750i
    So each of the arguments I will pass something into that function call (e.g. "apijobs( , , ,...etc) some type of info. But from Argument 5-9 not sure what its looking for like i don't know the "Tester serial number", AIF_KM or AIF_HAENDLER STRING
    Sep 2009
    Spain
    E60
    I have filled all the parameters for aif CAS but Tool 32 say UIF_SIZE_ERROR when I try to write
    WBAGM************;170703;6942487;6942487;0000000;0 00000;NFS01;0;004891DF200S
  1. Winkfp error 209
    By SPK1337 in forum Diagnostic Software
    Last Post: 09-03-2015, 04:42 PM
  2. WinKFP error after importing assembly line
    By that in forum Diagnostic Software
    Last Post: 09-14-2013, 11:56 PM
  3. WinKFP error, sgic.as2 file?
    By nightkrawler in forum Diagnostic Software
    Last Post: 04-05-2012, 06:04 AM
  4. How to fix this WINKFP error?
    By liuhuan in forum Diagnostic Software
    Last Post: 01-04-2012, 10:51 AM
  5. WinKFP error help
    By Viper1213 in forum Diagnostic Software
    Last Post: 09-12-2011, 02:07 AM
