Results 1 to 5 of 5
Thread: '01 325Ci - screwy blinker
    Oct 2007
    Bolton, MA
    2001 740iL, 2001 325Ci
    Hi all,
    Occasionally, when I turn on the right turn indicator, I immediately get the "fast blink" and figure, no problem: figure out which bulb is out and switch it. But then, it turns to a normal blink. I check all 3 bulbs, and they are fine.
    Kinda screwy, eh? thoughts? Contacts in the sockets seem good...
    Jay
    '01 325Ci Convertible, 5-speed
    '01 740iL, Stahlblau with beige interior & 18" M-Pars, GROM bluetooth
    '03 X5 3.0 six cyl, Gray on gray
    Mar 2015
    west chicago il
    01 E46 330i 5sp man spor
    Front turn signal sockets burn the center contact. Tail light ground connection is also a common problem.
    Sent from my SAMSUNG-SM-G870A using Tapatalk
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    The E46 sedans were built in South Africa. They suffer from bad grounding wires in the tail light harnesses. There’s a recall to repair the ground cable issue. Recalls never die. Go to dealer to see if the recall has been done in the car. If it hasn’t been done, schedule it to get it done. As noted, the front blinker sockets go bad on some cars. If it’s the cause of your issue see if the dealer will fix it for free (it’s called “good will”) or fix it for a reduced cost. Lastly, what brand of bulb is in the blinker that’s having issues? It matters.
    Oct 2007
    Bolton, MA
    Quote Originally Posted by MarcoZandrini View Post
    I'm pretty sure I got Osram bulbs at Autozone. I did notice the bulb I pulled out of the front seemed to have the bottom ...cooked off; degraded. I made sure the clean the contact point(s)....
    Mar 2015
    west chicago il
    Quote Originally Posted by jpilk99 View Post
    That's exactly what I was talking about when I said e46's "burn the center contact" on the front turn signal sockets. You will need a new socket and bulb. The contact is bad and it will happen again. What you did is just a temporary solution but should be fine until you get a replacement.
  1. WTB: '00 323Ci or '01 325Ci
    By 8immerphile in forum BMW Cars For Sale / Wanted
    Last Post: 04-17-2004, 03:08 PM
  2. Feeler: '01 325Ci Rims
    By cyrus_m3 in forum Wheels and Tires
    Last Post: 01-15-2004, 11:34 PM
  3. FS: 16" 01 325ci Wheels/Tires
    By DustinInDFW in forum Wheels and Tires
    Last Post: 11-04-2003, 11:12 AM
  4. Buying an '01 325Ci out of state - what to look for?
    By foRRREVerz in forum 1999 - 2006 (E46)
    Last Post: 10-01-2003, 02:05 PM
  5. 01 325Ci burning excessive oil - recall?
    By Dalton in forum 1999 - 2006 (E46)
    Last Post: 09-17-2003, 02:02 PM
