Results 1 to 21 of 21
Thread: E38 INPA friendly OBD2 mod....
    Mar 2018
    Bella Vista, Ar
    2001 BMW 740iL
    So, I got Bimmergeek's version of INPA up and running on my Windows 10 machine. Ordered up a 20-16 pin conversion cable, and a K+DCAN switchable cable. All was good in BMW diagnostic land. Except I was a little annoyed having to sit outside my car to read my modules (First world problems, I know). Really I wanted to be able to mess with stuff inside AND read the results. Out of the rain, and with the AC on if I choose.
    I had heard there was a way to rig up the 20 pin under the hood so you could get all your INPA goodness from the OBD2 port inside the car. Google didn't disappoint, but it did take a bit of searching. This is nothing new, just a little bit more detailed than what I found with google. I'm sure there are some great write-ups out there, I just wasn't finding them. So I made this one.
    **DISCLAIMER** This worked for me, I can't promise this will work for you. This is for E38 only, I have no idea if it will work for any other BMW of the era. If you break something, not my fault. If you car catches on fire, not my fault. If your ECU become sentient and enslaves you to force YOU to take IT to Walmart... not my fault. Use at your own risk **END DISCLAIMER**
    Links:
    Bimmergeek's "hacked" INPA to work with any Windows 64 bit install. Choose the "Standard Tools" download. Instructions on how to install are in a txt file in the download. https://www.bimmergeeks.net/downloads On a side note the current version is 5.0.6 with english menus and German error codes. He had a full english version but it had bugs so he pulled it. At some point he's stated they will repost the full English version.
    Cable from Amazon I'm using (Bimmergeek also sells a high quality one, but I didn't know that till after) https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    You'll need:
    Flathead screwdriver
    90 degree pick, or something of the like
    1" of wire or so
    Soldiering gun
    Soldier
    More skill than me with using the last two
    30-60 Mins of your life
    There is more than one way to skin this cat. In the end the main objective is to link Pins 17 and 20 together in the 20 pin port CAP under the hood. One of them is used for the normal OBD2 communication (Engine codes and the standard OBD2 stuff) the other is used by INPA and the like for talking to all the other modules. Stock our cars only send the OBD2 data to the OBD2 port. But if you link them together it will start sending EVERYTHING to the OBD2 port. No more need for a 20-16 pin adaptor cable. You can just hook up to the OBD2 port inside for all the BMW Standard Tools to work! Back to skinning cats, there are multiple ways to do this. After considering my options I went with the below because I liked the idea the best. This just seemed the easiest "clean" way to do it. I spent several hours with INPA to verify it worked as expected. Worked fine for everything I tried. I didn't try programing or other tools. But I've read they all work fine with this mod. But I cannot vouch for anything but READING with INPA. The best part of this approach is that it doesn't "damage" or rewire your 20 pin or OBD2 at all. So you can always go back to a 20-16 pin adaptor if needed at any time. Take off the cap like normal, and presto! Back to stock setup again.
    So on to it! The first thing is to get the cap itself off. Unless yours it broken, it should be attached to the port by a plastic teather. I found prying with a flat head screwdriver where it snaps into the middle of the cap worked well to remove it. Once you have it removed, if you turn it over you'll notice 5 pins coming out of a circuit board mounted into the cap itself. What we want to do is get the two pins in the picture below linked together:
    It's important we get the right ones!! At this point you could rig up something to just connect the two and be done. A paperclip, a wire, or anything else that conducts. However I had visions of other pins(the female side of the pins) in the port somehow contacting it, or a host of other issues with that solution. So we're going to dig a little deeper here. For my solution we need to get that circuit board out. It's held in with 4 plastic rivets circled below:
    I got it out by taking a small pair of needle nose pliers and "crushing" the ends of those rivets until I could pop it out. The board itself is pretty beefy, but I don't suggest just prying it out. Might work, might break your board. Once I had them to the point I thought I could get it out, I used a 90 degree pick to pry it out from underneath. If you don't have one then get inventive, my only suggestion here is try to get something under the board and pull up. There isn't tons of room on the side for a flathead so you'll mostly be forcing it sideways and not up. But might work. To me this is the only part with any risk. Just be patient and smart about it.
    If all goes well, you'll have a nice unbroken board in your hand:
    Turn it over and I've marked the two you want to link together again:
    The easiest way in my head to keep it straight was to make sure I was working with the two that would have to cross over the pacman cutout in the center to link. All the others close by could be "linked" without going directly over it.
    Since you'll have to route around the packman slightly, you want to make sure your wire is long enough to go around it. I ended up with something like this:
    Continued on next post due to per post limit of pictures reached....
    2001 740iL "Silver Beauty"
    1986 Porsche 951 "Silver Bullet"
    1987 Porsche 944 NA Auto (rebuilding for my son's first car)
    https://home.doonze.net/filepage.php <- BMW/Porsche doc's and files, work in progress
    Mar 2018
    Bella Vista, Ar
    2001 BMW 740iL
    Continued...
    My only suggestion is to use the smallest wire you can find. I keep a roll of 16 gauge around, but that's too big. I cut some off an old stereo I had laying about, but it was still really too big for my taste. I'm guessing what I used was about 22 gauge? Ish....
    I'll post the next one so you guys can make fun of me. I SUCK at soldering. So this is how I kept my wire in place:
    LOL, yeah... anyway...
    So the joints on the board are very hard. I don't think I got even close to melting them, but I also had a little trouble getting my soldier to stick to them. After several attempts (as in, my soldier job didn't "stick", test pulls pulled it off easily) I finally got a decent job done:
    Not pretty, but it works. Putting it back together, my thoughts about using too big of a wire turned out to be somewhat founded. I could tell it was keeping the board from sitting 100% level. It was slight, but if I did it again I would have found smaller wire. This worked however. I thought about putting some JB Weld back over the rivet holes, but to be honest I didn't want to wait for it to set. So I used some brush on JB Weld "super glue" I had instead. I don't plan to ever need to take the cap off again now, but I'm pretty sure it will hold well enough.
    Anyway. Tested and working, as long as my soldier job holds up.
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Excellent work - and very useful in rainy England!
    My BMW Repair YouTube Channel
    Mar 2018
    Bella Vista, Ar
    2001 BMW 740iL
    I don't know if anyone else cares, but I did figure out how to create a direct INPA menu for E38, so you don't have to go to "Older" and scroll down to E38. Set it up on F9 and moved E89 to <shift>-F4. If anyone is interested I'll post up how. Figured out on both vanilla INPA and Bimmergeek's INPA.
    Aug 2017
    Wayne,PA
    740iL (E38 '01)
    This is interesting, thanks! I might do it.
    Mar 2013
    Sonora, ca
    2001 740il
    Sweet mod! What version of inpa do you have
    Mar 2018
    Bella Vista, Ar
    2001 BMW 740iL
    Quote Originally Posted by Sundaycruzer View Post
    Bimmergeek's INPA 5.0.6. It's a "hacked" version to work correctly on 64 bit windows vista/8/10 ect. I'll link in the first post, forgot to do that.
    Aug 2018
    NJ
    E38, b4 tdi
    Love this. Thank you for all of the great details!!
    Sent from my VS501 using Tapatalk
    IL
    2000 740i sport
    You can also just do what 7thDimension did as well...
    Sent from my SM-N960U using Tapatalk
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    He's chopped off the Pacman in the middle!
    IL
    2000 740i sport
    https://www.bimmerforums.com/forum/s...5-OBD-Port-Mod
    And yes 951Dreams mod with the write up is a much more clean way to do it permanently...
    Jan 2019
    Connecticut
    E92, E46, E36
    Anyone know if this will work for 06/2000 e46?
    Sent from my SM-G960U using Tapatalk
    Mar 2013
    Sonora, ca
    2001 740il
    Old thread but found an easy way to do a clean jumper for this mod.
    Simply solder a jumper, instead of using a piece of wire. Clean of protective coating and run a bead of solder to jumper.
    Nov 2005
    canada
    2001 740i
    Is this board inside of the plastic cap that covers the port?
    1991 318is
    2001 740i
    Mar 2013
    Sonora, ca
    2001 740il
    Quote Originally Posted by bymep View Post
    Yes, there are plastic tabs that you break off to release the circuit board, then I epoxied the circuit board back to the cap
    Dec 2021
    Thousand Oaks, California
    1998 BMW 740i base
    I've improved my soldering skills over time. Having a small container of rosin flux helps greatly in attaching new solder to existing older soldered joints. All it takes is a dab. You'll also do well to use a small wire brush carefully or sandpaper or file to slightly rough up intended spot your wanting to add solder to. Lastly, when trying to heat up old soldered spot on pc board ect. having a spot of fresh flux & solder in your iron will attach to old solder very quickly. Seems that older dirty solder spot is in a caccoon of sorts and will not accept new solder until the dirt surface is penetrated.
    Make sure you remember the orientation by marking how board sits in the cap prior to removal.
    Dec 2021
    1998 BMW 740i base
    But wait....You've cut off the black plastic pin with the divit in the side used for orientation. Your not mentioning this for us newbies!
    Should. All 16-20 pin plugs under hood are wired the same.
    Jan 2015
    Durham, NC
    2001 740iL
    Bravo @951Dreams. One quick question I have for you, in your sig it says you have a 2001 740iL, same exact one I do. Is that indeed the car you did this mod on? I'm just paranoid of breaking stuff
    Edit: never mind, I found in another thread that all 96-01s are run the same way, regardless of facelift. Some 2001 E38s don't even have the 20-pin connector but mine does.
    2001 740iL
    Aug 2012
    Simi Valley, CA
    328, 525, 740, R1200RT
    Sorry for the silly question, but INPA 5.0.6 doesn't show an option for the E38. Is there a newer version that does? Thanks in advance.
    Rutland, Vermont
    E30 E38 E46 E85 F150 GTI
    Quote Originally Posted by Old525i View Post
    Look under the “older models” tab?
    2000 740i Sport | 2004 330xi | 1988 325i Vert | 2003 Z4 2.5 | 1995 Ford F150 | 2018 GTI
    Aug 2012
    Simi Valley, CA
    Found it! Thanks.
  1. Friends of E38: INPA, tools and assistance locations
    By Xephius in forum 1995 - 2001 (E38)
    Last Post: 06-07-2011, 09:23 AM
  2. e38 e39 x5 Perfect Modded Cluster
    By E39 Prototype in forum Interior Lighting & Body Parts
    Last Post: 02-13-2011, 09:01 PM
  3. E38 INPA Analog DME values
    By IcemanBHE in forum Diagnostic Software
    Last Post: 07-17-2010, 12:24 AM
  4. a "friend" secretly "modded" my car last night
    By bmmeup325is in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 03-29-2007, 02:50 PM
  5. What Software for OBD2 Mods?
    By mikeo in forum 1992 - 1999 M3 (E36)
    Last Post: 06-29-2003, 01:12 AM
