Results 1 to 5 of 5
Thread: S50B30 Vs S50b32 Wiring Harness, what are the differences?
    Apr 2012
    Jacksonville, FL
    1997 M3/4/5 1998 750iL
    Hello everyone, i need a bit of help.
    I am currently working on another euro swap here in the US this time with a S50B30. I want to know what is the difference between the b30 wiring harness and b32? I have a spare LHD harness from my b32 and wondering if that could be salvaged to use on the b30. i do have a proper b30 dme coming as we speak.
    From what i can find they have different part numbers
    S50b30
    https://www.ecstuning.com/b-genuine-...s/12511401275/
    S50b32
    https://www.ecstuning.com/b-genuine-...s/12511406121/
    Any help would be appreciated,
    Thanks!
    Instagram: @Tommy604604
    Rare Wheel Fanatic
    1998 E38 750iL
    1999 E36 M3 Techno Vert
    1997 E36 M3 S50B32
    Mar 2008
    West Covina, CA
    97 M3/4/5, 98 M3/2/5
    Could probably contact Alex L. xyobgyn@aol.com pretty much one of the most knowledgeable guy on the "euro" or rest of the world motors.
    Apr 2012
    Jacksonville, FL
    Quote Originally Posted by tofunin View Post
    Thanks for the reference! He pointed me in the right direction and i managed to source the correct harness.
    should anyone come across the same question the two harnesses are very different, the s50b30 harness has a second dme(VNC) for the vanos along with the main DME.
    Rare Wheel Fanatic
    1998 E38 750iL
    1997 E36 M3 S50B32
    The Netherlands
    DE-spec E36 328i/M3 cab
    The B30 also has a TDC sensor (on the vanos bridge) the B32 hasn’t.
    And for the B32 there is the SMG version, where there is a separate control unit for the SMG and the extra wiring going to the shift solenoids, pumpmotor, pressure sensor.
    And of course the wiring for the 2 extra vanos solenoids for the exhaust side.
    IG:
    Feb 2008
    USA
    M3 Cup
    The 3 liter S50 harness has a separate VANOS connector. On the 3.2 liter the VANOS is built into the main ECU so it has only one connector. Coils and injector connectors are all the same otherwise.
  1. Auto vs manual wiring harness
    By E36matyac in forum 1991 - 1999 (E36)
    Last Post: 01-21-2014, 09:49 PM
  2. auto vs manual wiring harness
    By berlind in forum 1983 - 1991 (E30)
    Last Post: 03-06-2011, 01:58 AM
  3. E36 S50B32 Wiring harness AND DME
    By e46_lover in forum BMW Parts Wanted
    Last Post: 10-20-2010, 09:34 AM
  4. s50b30 vs. s50b32
    By Corey Milne in forum 1994 - 1999 Euro M3 (E36)
    Last Post: 10-31-2009, 03:52 PM
  5. S50B30 vs. S50B32
    By steve shadows in forum 1994 - 1999 Euro M3 (E36)
    Last Post: 04-08-2009, 09:46 PM
