I have a m20 from an 87 325 , eta lower end , 885 "i" cylinder head
located in new haven Connecticut area. pickup prefered, looked into shipping options and will cost big $$$
ehturbox@gmail.com
drop in ready, ready to run
Stock lower end originally had about 200k on it
885 head unknown mileage but seller is a reputable bmw guru and said it had just come from the machine shop and checked out good
1500 miles ago
new rod and main bearings
new piston rings
new gaskets all around
new stock head gasket
arp headstuds
new valve cover gasket
new single output water pump
new timing belt and pulleys
currently has a new style crank pulley with the crankshaft sensor mounted in the front of the motor (car originally had the 2 sensors in the bell housing)
oil pan has 10an bung welded on for turbo drain(currently capped)
oil pressure port has a T for a mechanical gauge(not included) and turbo oil feed
new stock fuel pressure regulator
42lb injectors
new ngk plugs
new taylor cable 10mm wires
new cap and rotor
will sell with ems pro (based off of ms1/extra) and harness for this motor
runs on current tune but would have to be fine tuned for specific setup you go with
original parts included
alternator
throttle body
m50 tps sensor with adapter bracket
stock fuel rail
stock intake manifold
various sensors
will include for extra price
msd blaster 2 coil
msd digital 6al ignition controller
any questions feel free to ask
Are you selling the throttle body seperately?
