Results 1 to 6 of 6
Thread: Lcm vin coding.
    Aug 2017
    Tampa Bay Area florida
    1998 528i
    Lcm vin coding.
    I've attempted to research and must be missing it due to the insane about of coding info on this site.
    I may be swapping my LCM to a used lcm 3 for facelift update and want to ensure I can code it correctly.
    Can DIS/GT1 code the vin and user information as well as relatively easily change the parameters?
    Or will I need PA Soft.
    1998 BMW 528i My First Build
    Jul 2005
    Sacramento, CA
    70hp of fury
    From what I can gather, if you have the software and the scanner, it's fairly easy. I'm a noob at this coding crap too, and there's tons of info on here. I'm trying to fix the foglights on my E46, fuses and bulbs are good, bought a used LCM, but it made my rear fogs come on, and changed the rear driving lights to the upper 3rd, not the lower 3rd, weird. Is the software you are referring to a standard or BMW specific programmer?
    '89 325i = 15.6@91
    '03 325i 5spd sedan.
    Atlanta, GA
    14 F01 750i 14 F10 550i
    To avoid Tamper Dot BMW Scanner to set the mileage and NCS Expert to Code your vehicles options.
    Aug 2017
    1998 528i
    So I can't code the options with bmw scanner as well I have bmw scanner just working on the dang drivers now. I have DIS but haven't tested it
    Atlanta, GA
    You can Code options with BMW Scanner also.
    Aug 2017
    1998 528i
    Ok perfect NCS expert looked confusing. Now I just have to figure out drivers to make bmw scanner work does it work better on windows 10 or an xp virtual machine?
  1. E38 LCM / LKM coding question
    By mein 7ner in forum Diagnostic Software
    Last Post: 10-08-2010, 08:06 PM
  2. Can you figure out the color out of the VIN code?
    By Robertin in forum 1983 - 1991 (E30)
    Last Post: 04-05-2010, 06:12 PM
  3. Where to get Airbag module VIN coding in MN?
    By strobeyprobey in forum Great Lakes - US
    Last Post: 10-16-2009, 12:46 PM
  4. VIN code
    By Kristov in forum 2001 - 2006 M3 (E46)
    Last Post: 01-27-2009, 02:13 AM
  5. E32: what the VIN codes tell you....
    By shogun in forum 1988 - 1994 (E32)
    Last Post: 12-16-2007, 10:17 PM
