Cool! Thanks Randy. Shipping will hurt, but I may as well get the best product on her. I'm a big fan of eliminating unnecessary connections for the reason you mentioned.
No CDV in the M, right?
George Roffe
98 M Roadster
01 325iT
Ah, found my answer I think....
The M does not have the CDV, but it has a restrictive line that (I guess) performs the same or similar function.
https://www.bimmerforums.com/forum/s...ght=lock+valve
George Roffe
98 M Roadster
01 325iT
Hey Randy, I just picked up rogue engineering SS line for my 2001 M roadster. Are you telling me that I do not need to disconnect the hard line from OE line and connect it to RE line before installing it? So I remove the OE line and install RE SS 1 to 1? It seems kind of short comparing to OE line.
There are two general approaches the aftermarket takes to the braided lines. One preserves the hard line attached to the slave cylinder (line will have a female fitting). The other has a male fitting and bolts up to the slave replacing the hard line. If you use the version that screws in to the slave, you won’t have to worry about the CDV. If you use the female style, just remember to remove the CDV restrictor from the end of the hard line.
I guess I was talking about rogue engineering SS line for s54 engine. http://www.rogueengineering.com/Rogue-Engineering-Stainless-Steel-Clutch-Line_p_134.html Model SS-...-03. I believe it requires a removal of the hardline from OEM. I wonder if I can pick that part up new?
Looking over the Rogue web page, they make a big deal about preserving the factory hard line. I believe either approach should work fine. I have put a braided line on one of my BMWs at a club DIY when it was on a lift. That line was set up to preserve the factory hard line. Really easy install. Pulled the CDV off the hard line at the same time. Had access to a pressure bleeder, too, so there were no complications with trapped air in the lines.
https://www.bimmerforums.com/forum/s...for-M-Roadster
Perhaps look into changing to the 325i clutch slave. Check out this Thread. It cured my engagement issue.
Bill
I have a 2002 Z3 3.0i. Want to replace the OEM rubber clutch line with a stainless steel line. Rogue Engineering and UUC both told me they do not make a clutch line for my appication. I did do a CDV delete. Reading this thread it seems some of you have used these brands with success. What clutch line did you order?
Hey, I have the same car- 2002 3.0. I used the Bimmerworld clutch line:
https://www.bimmerworld.com/BimmerWo...-536-0002.html
I think it's very likely any of these others mentioned will work with the 3.0 and with all the Z3 models that have the small hard line at the clutch slave cylinder... The Bimmerworld one is listed for all types of Z3, since it's the type that replaces both the rubber line and the small hard line if you have one.)
(By the way, ignore the e46 video on that page, it will anti-help you)
I wrote up my notes on this process for the 3.0 in this thread if you want to read it:
https://www.bimmerforums.com/forum/s...-Hard-to-shift
$18.50 but I had someone else install it because I don't have the specific bleeder and didn't want to deal with it: https://www.pelicanparts.com/More_In...CLU&SVSVSI=625
Same as dude above me I got the Goodridge braided stainlesssteel line simply because it was from PelicanParts and cost 18 dollars, although unlike him I installed mine on the 2001 3.0. It’s quite a bit shorter than 2001 3.0 oem so I recommend getting the Clutch Delay Valve Delete if you plan on simply removing the stock Clutch Delay Valve I’m not sure it would stretch far enough. Shifting’s never been better though and no leaks in the past few hundred miles since install so I recommend. Also you must compress plunger to bleed, you just must.
