Looking to replace my stock rubber clutch line.
Has anyone used the ECS line? https://www.ecstuning.com/b-ecs-part.../009535ecs02a/
How was the fit on install? Would you recommend it?
What other brands should I be looking at?
Mahalo! (thanks) Jeff
I installed a Rogue Engineering SS Clutch line and it was a perfect fit 4 years ago. Used Motive power bleeder and worked well. UUC also makes one, but not sure of the fit
I twisted off the hard line while I was trying to replace mine. Make sure you're securing the hard line while trying to undo the coupling.
I've been using the Rogue SS line for over a year now with no troubles (2000 Z3 M Coupe). The line itself fits well and was easy to install. Getting to the slave and bleeding different story.
Just installed the same one a few weeks ago, not hard to do, especially if you can get Tim to do it for you!! Really not hard at all, depending on mileage, you might consider replacing the slave cylinder while your in there. I wish I had replaced mine when we had it all apart. We replaced my clutch line as I was having difficulty getting in gear with clutch engaged. Replacing the line helped a lot but I can still feel the transmission engage the driveline when I begin putting the car in gear. My next step will be to replace the slave and pray it works.
Good luck, plenty of tutorials on the site!!!
I replaced my line about 16 months ago, much better feel. However, you WILL need a Motive Euro Power Bleeder, and the bevauto clutch bleeder tool, and a couple flare nut wrenches (11mm and 14mm, i think). Some people can bench bleed. There is a post somewhere by Randy that tells how to do this pretty damn well. The key is getting the air out, not as easy as it sounds. The #1 rule is if you bleed and your clutch petal is not rock solid, like will not budge, you have air in your line. So do it again! lol https://www.bavauto.com/bmw-clutch-slave-bleed-tool-cbttool
• Built S52 w/Dinan ISR-3 kit, NickG Stage 2+ Tune, Dinan Vortech V2 Supercharger, Dinan Air to Air Intercooler, Dinan CAI, Porsche 803 HFM, Buldogge 6" crank pulley, Griptec 2.90" blower pulley, Eurosport UD pulleys, Dinan 3.38 Diff, Dinan front/rear Swaybars, Dinan springs, Koni Yellow Sport Struts, Ground Control end links, South Bend Clutch Stage 3 Organic, AASCO Light Weight Flywheel 18.5#, Zionsville Radiator & Oil Cooler, Riot Racing BBTB, Schrick Intake Manifold, 42# Injectors, Schrick cams 264/256, Forged Wiseco pistons 9.0 comp., Forged Eagle rods, Supertech dual valve springs & valves, VAC crank & bearings, Supersprint mufflers, Euro Z3 midpipe, Raceland euro headers, Walbro 255, Bevauto ignition coils, Vortech Mondo bypass, Bailey Diverter DV30, Ireland Rear Subframe Bushings, Mason Engineering Strut Brace, Mason Engineering Clutch Petal, Apex 18" EC-7 Wheels, Full Custom Sound System, two trunk lids (with & without OE spoiler), Hardtop, Trunk full of AK's...
You definitely don’t need a power bleeder.
I install everything but leave the slave loose in the transmission. When all of the lines are tightened pull the slave out position the bleed valve straight up, loosen it.
With your free hand slowly push the plunger in until it is almost bottomed out. Tighten the bleed valve and let the slave return to the extended position. Repeat until there are no bubbles.
The system is gravity fed, and self bleeding if the slave cylinder has no air in it.
UUC also makes the clutch line. I haven't had any leak since the install 5 years ago. And I took the easy way (Motive bleeder).
If you need to replace the clutch line, I would also recomend inspecting the brake lines and replace them with SS as well so you can save on bleeding...
2000 Z3 M Titanium Silver / Imola Red+Black Nappa
2011 328i E92 Space Gray Metallic / Leder Dakota+Oyster
Since 1987 12 euros / 2 kdms / 2 jdms
- Zach
Thank you everyone!
I’m going to give the ECS a try. They have a sale and with shipping it will be less than the others.
Fingers crossed install won’t be to bad or I should say the bleeding.
I've replaced several clutch master cylinders on Z3's and E36es for this issue. Including my own car(s). I actually have an S54 roady right now that wouldn't even go into gear once it was hot. Replaced the master and the worn out clutch pedal, problem solved. Just something to think about.
96 320i Touring
98 Z3 2.8 Roadster
01 PY M Coupe
96 Z3 1.9 - DASC
95 318ti Clubsport
94 Miata M-Edition
13 smart fortwo
Tim, good to know, thanks. I'm going to try to get through the summer as it is, unless you'd advise against it. I've spent more time underneath the car than in the driver's seat.
I have had a shop replace the clutch line with a stainless from UUC, bleed the clutch fluid and install a Mason pedal. The shifting is fine, however getting into Reverse or 1st from Neutral at a dead stop is usually not as smooth and easy as I would like.
And on cold morning starts in the garage, I can feel the transmission trying to engage the driveline when I begin putting the car in Reverse. The resistance going into gear causes the car to move a fraction of an inch.
Are these posts suggesting that I should replace the slave, or master, or both?
BMW MOA 696, BMW CCA 1405
If it's as you describe when cold, but fine when hot, I would look first to air in the line. Air contracts when cold, thus possibly not moving the slave as far.
This is another issue I need to address with my Roadie I had off the road for 4 years. A couple of years before I pulled it off the road, I replaced the slave and I think the master as well (IIRC). I'm pretty sure because I remember it being a PITA getting to it.
So, following up here, how did you make out with the ECS line? Good thread, but like so many, it's left hanging without the follow up answering the original question. I will probably be ordering the line in the next week or so. Not sure if I'll install it during the Thanksgiving break (that depends upon how well my oil pan gasket replacement goes in my E46).
And, to continue other side conversations, my clutch currently takes up RIGHT off the floor. Disengagement is OK when cold, but problematic when warm. At times, I've had the gearbox in gear and the clutch fully depressed and the car will move a little. Clearly some drag on the clutch. I'm hoping the line will solve this for me, given the master and slave have been replaced once already. If the line doesn't do it I guess I'll just have a potty mouth and readdress the master and slave.
George Roffe
98 M Roadster
01 325iT
Your symptoms are exactly caused by a ballooning line. I had the same experience until I replaced it.
One more question if I may....
Rogue Engineering makes a big deal about the hard line they have at the end of the hose, and matching the factory line. Is this a big deal or a non-issue? The prices of ECS, UUC, and Rogue are all close enough that if it is a real issue, then Rogue it is, otherwise, I can order either the ECS or UUC from ECS along with some other parts and save on shipping.
George Roffe
98 M Roadster
01 325iT
- Zach
I've used the Bimmerworld line (with CDV delete) without issue. I think the UUC line from ECS needs a separate CDV delete.
Didn't I read the CDV is not used on the M?
All 4 are close enough in price that price is not an issue. OK, the ECS is $10 cheaper, but that is not an issue for me if one of the others is truly a better choice. My big question is related to Rogue making a big deal about the angles on the end of the line. Is that a big deal or something to more or less not worry about?
Oh, and I was reading another thread that talked about a special tool to bench bleed the slave. Is it out of favor to bleed it by pressing the shaft against the bellhousing? That was the recommended method back when I replaced the slave.
Sorry for all the noobish questions (definitely not a noob, but just back here after a 4 years absence), but I'm just trying to do my homework. I've got a lot of maintenance projects to do on both cars.
George Roffe
98 M Roadster
01 325iT
I'm a Big Fan of this! Historically, I have always__when needed__replaced the clutch hose using the OE 3.0 hose (21 52 1 159 714) as it eliminates the additional short steel tube (potentially another fitting to leak, or seize) and bracket. The Rogue hose duplicates the 3.0 setup, and it's Teflon/braided stainless.
My recommendation is to use the Rogue product.
