Results 1 to 13 of 13
Thread: Turbo s50 whats the issue
    Feb 2012
    Jamaica
    95 BMW M3 Arctic grey
    Good Day Gents
    I went to the dyno a couple days ago. Built S50 9.0 CR GT35R on a 666 manifold 63 back housing with a M50 cams (long story on that on) 3inch cold side and 2 1/4 hot side for the intercooler MS3 as the managment. 15psi on 90 octane pump gas. What is causing the the top end to fall off so badly?
    Thanks in advaince
    Mar 2012
    Renton, Wa
    98 m3
    I’m going to take a wag. Upload a picture where we can read the afr and I can do better.
    1. Tuning
    2. Back-pressure
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
    Feb 2012
    Jamaica
    AFR is 11.7 not more at wide open throttle.
    Could it be the vanos mapping? We did it 15 degrees across the from 3500rpm and off at 5000rpm
    Mar 2011
    Kingston ,Jamaica
    1997 328i turbo
    What size turbo housings ?? What cams ?? Aren’t you on standalone. Do you have the log ?
    Apr 2015
    Tennessee
    1998 BMW 328i
    Im no expert but that hotside sounds small and those cams sound slow.
    Aug 2012
    CT
    Twin turbo LS E36 M3
    Everything in here
    Or the vanos is staying active
    Wait, i just read the comments in here
    The VVT settings should be set to ON/OFF. Meaning you wont be specify a certain number of degrees, but rather when the vanos solenoid should be on or off
    Generally speaking, your gonna want the vanos active at like 1200rpm and off around 4k.
    You can easily find this out by making back to back dyno runs with the vanos on all the time and then another pull with it off the entire time. See where the 2 graphs would cross if you layed them on top each other
    328i Sedan Twin s366's, 6.0LS, TH400, MS3 Ultimate
    9.20 at 150 on 22psi
    Oct 2008
    Albuquerque
    a m3 on a 7675
    That .63 housing is waaay to small get somthing atleast i. The .9x range and watch what happens.
    The differance in spool will be a few 100 rpm.
    World record holder for a m52 stock bottom end.
    9.41@153 c4 auto 28" et streets, e34 3.64 gearset 900+hp
    E36 chassis irs world record holder 8.49@162
    Th400, e85, 7685, m50 intake 26.6 lbs of boost
    Feb 2012
    Jamaica
    Thanks guys for the input really appreciate it.
    @Dburt we actually did all Zero's in the vvt table for a few runs the car lost over 50 whp and TQ and then did a few run with the vanos activated from 3500rpm and off at 5500 rpm @10 degrees all the way up 20 degrees, no real change happened at the 20 degree so we left it at 15 degrees. the car lost power at the 5500rpm so we decided deactivated the vanos at 5000 rpm the car gained a bit of power in that area. when we go back to the dyno we will try the earlier activation of the vanos.
    @ DasBoot I am in the process of looking for the bigger housings
    Manchester, N.H.
    96 332IS 6466 turbo
    Its the cams causing the drop in power up top. Not the small back housing. Sure a bigger back housing will flow a bit more, but those shit cams are killing your top end.
    Aug 2012
    CT
    Quote Originally Posted by fastboy View Post
    Your VVT settings should be ON/Off, not PWM. The vanos solenoid in the older 24v stuff is not meant to PWM.
    Meaning, you shouldn't be targeting an angle in your tune. You should be targeting at what RPM and load the Vanos should be on or off.
    But either way, ur cams suck.
    Feb 2012
    Jamaica
    @Dburt noted I will be revisiting the targets as was suggested for the vanos angles as soon as I can get back on the dyno, also noted on the sucky cams lol, I am thinking of getting the schrick camshafts 264/256 would that be a better choice?
    As for Timing what's a medium timing figures compared to a high timing figures?.
    Jul 2005
    California
    Bima
    pretty interesting i thought twin cams rev out WAY more that's like an m30 powerband.
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    A little turbo E36M3 trapped 135 mph this year with 0.63 JB PT 6262, comparable to GT35R. Yes, it was running more than the 15 psi of the OP’s car, but I would think it was also doing better than 350 STD Dynojet at 15 psi.
    Log boost and AFR for a start.
  1. Code 1222 and some AFR issues for turbo s50
    By Pring in forum Forced Induction
    Last Post: 10-01-2015, 01:19 PM
  2. For Turbo Cars: Oil Starvation Issues under Hard G's?
    By RRdawho? in forum Forced Induction
    Last Post: 06-30-2005, 12:38 AM
  3. People with TT Turbo...Vaccum lines blowing?? issues?
    By Colo97M3 in forum Forced Induction
    Last Post: 06-15-2005, 12:56 PM
  4. s50 swap driveshaft issues help me!
    By xvxax in forum 1992 - 1999 M3 (E36)
    Last Post: 06-09-2005, 01:04 AM
  5. Turbo S50 motor in E30
    By lowendesign in forum 1983 - 1991 (E30)
    Last Post: 07-19-2002, 09:29 AM
