Results 1 to 23 of 23
Thread: E36 M3 Front Wheel Bearing Life On Track
    Cincinnati
    M3
    I had the driver's side front wheel bearing go out on me at the track last weekend, fortunately I was able to find a replacement at a nearby O'Reilly's and get back out there.
    The bearings had about 20k miles and this was their 5th weekend on the track, but I was a little bit surprised that it went. How does this line up with other people's experience? Do these bearings need to be replaced preemptively? Are there large differences between the BMW part and OEM replacements?
    Feb 2016
    NJ
    E36 M3 SEDAN
    Talking to the guys who run E36 race teams, it seems that some OEM brands do better than others. Even then, it is a bit hit or miss. The one team I talked to swears by FAG front hubs; they last at least a full season. I'm using the brand they've had bad luck with and currently have 10-12 hours on them without issues. Think it is a bit hit or miss.
    Nov 2001
    Parker, Colorado
    Holden SSV, GTS2 E36
    I run the FAG brand bearings and replace them annually (GTS2 car).... down time is $$$$.
    GMC 2500
    1992 318is running in GTS2
    2014 Holden SSV
    Ottawa, ON, Canada
    e90 M3,X5,e46 racer
    SKF brand usually for us, and typically 2 years. Cheap to replace. We've had a couple fail, but that was early in our career ... unknow age
    Check out the 8legs Racing page: https://www.facebook.com/8legsRacing/
    Aug 2008
    Topeka, KS
    1999 M3
    I read a while back that repacking them with redline CV2 High temp high speed bearing grease has doubled the life for some race cars.
    Joe
    Ottawa, ON, Canada
    e90 M3,X5,e46 racer
    Quote Originally Posted by Mr Estoril View Post
    Yup. The problem is that the new design is almost impossible to take apart. Now I just take off the seal, wipe the old grease out, and shove some CV2 in it ... better than nothing, and it hasn't been an issue for us.
    Aug 2012
    Central, MD
    1995 M3
    I change both fronts yearly. (25-30 HPDE days/year). I've proven several times they last less than 2 years.
    I've been using FAG from FCPEuro (free replacements!)
    Cincinnati
    M3
    Thanks guys, looks like I should start changing these on a regular basis
    Springfield, IL
    '95m3(Avus)/996tt/4.8is
    Can someone weigh in on the effects of a wheel bearing going bad mid track event? Noises? Wobble in steering wheel? Want to get a better idea for when it happens to me! Will order some spares....
    Aug 2012
    Central, MD
    1995 M3
    From memory, none of mine (2 or 3?) that have gone bad during an HDPE event have had any symptoms other than noise...waaawaaawaaaa...at low speed. And I've always finished the day/weekend on said 'bad' wheel bearing. Even rotating the tire by hand, and yanking around on the wheel, showed no symptoms. IIRC, once removed, I could easily feel that 1 of the 2 bearings in the assembly was rough/bad, but 1 was still good.
    Springfield, IL
    Thanks aeronaut. Was hoping you would weigh in. I may swap mine this winter and keep one of them as a backup since they are fairly easy to change out.
    Aug 2012
    Central, MD
    1995 M3
    That's a good plan! As expected, my left one is always the failure.
    Aug 2009
    Metro DC
    79 323i, 94 325is, 13 M3
    Holy cow, I had no idea these things only have like 30 track days in them.
    I hope they are easier than the rears were. That job was interesting.
    If God meant for man to motor-swap LS engines into track cars, He wouldn't have created Corvettes.
    Cincinnati
    M3
    Quote Originally Posted by olemiss540 View Post
    It started as a 1/rev thumping for me, always worse when the bad bearing was loaded, but always present. I could also feel it through the steering wheel.
    We jacked the car up and tried to wobble the wheels to check the bearings, but they seemed fine. For troubleshooting purposes I rotated the tires, and the noise and shaking got better.... for a session.
    The second session after that the thumping got worse and my steering wheel started shaking badly. This time we jacked the car up and we could easily wobble the wheel on its bearing.
    So, you could start to hear thumping.
    Quote Originally Posted by JBasham View Post
    We were able to change it at the track pretty easily. The bearing + hub assembly is just fitted on the spindle behind the rotors. The key is to have/find the right socket, and a strong electric impact wrench helped immensely.
    Aug 2012
    Central, MD
    1995 M3
    Tires make a huge difference in wheel bearing life. Wheel bearings don't get along with R-comps.
    Jan 2002
    North Augusta SC
    I’m surprised to see the kind of failure rate. I’ve replaced mine three times over the last 19 years and 30K track miles. Only one showed any sign of failure. No Hoosiers, but mostly Z214 and NT01.
    '95 M3 S54 Track Toy
    '12 X3 35i M-Sport
    '16 VW Golf R
    Jul 2012
    Orlando, FL, USA
    1993 BMW 325i
    Strange to see so many failures, my non-m has been run hard on r-compounds for at least 5 years, and to my knowledge are the original bearings from 1993. Guess I've been lucky and just not had to deal with it yet.
    Ottawa, ON, Canada
    e90 M3,X5,e46 racer
    Its not so much failure rate, as a cheap preventative maintenance. For HPDE, not a big deal, but for a race weekend where you're in for several thousand $$$, you do everything you can to not have any preventable failures on track. When we were trying to be hard-core competitive, our moto was that if we had something fail once, it would automatically go into off-season maintenance schedule so that it never happened again.
    Also, big load difference between r-comps and Pirelli slicks
    Springfield, IL
    Quote Originally Posted by ScotcH View Post
    I am usually in for several thousand $$$ on each HPDE weekend, so joke is on you I guess..
    Apr 2018
    Michigan
    1995 BMW M3 Coupe
    What are you guys doing if you have lug studs and the bearing fails? Do you have extra studs that you put into the new hub beforehand so it's ready to go? Or do you replace the hub and just run it with lug bolts until you can change the studs over to the new hub?
    I've only just bought my track only car and haven't had a bearing fail yet, but I want to plan for it.
    Aug 2012
    Central, MD
    1995 M3
    They come out pretty easy with a little heat, and something like this:
    https://www.amazon.com/ABN-Universal.../dp/B077Y6JRP9
    I just put the stud remover over the non-threaded portion of the stud, and they pop right out without any damage.
    Ottawa, ON, Canada
    e90 M3,X5,e46 racer
    Quote Originally Posted by Goallie11 View Post
    Yeah, we prep the new hub with studs already. Good to replace the studs as well every few years, so this does both
    Nov 2001
    Parker, Colorado
    Ditto. Two hubs in the trailer with studs already installed and ready to go. Spare hub nuts as well and the big-ass socket in the same box.
    GMC 2500
    2014 Holden SSV
  1. E36 M3 Front Wheel Hub/Bearing FYI - $$
    By AlmostSiR in forum 1992 - 1999 M3 (E36)
    Last Post: 09-08-2011, 12:04 PM
  2. M3 front wheel bearing assy
    By Balthazarr in forum 1992 - 1999 M3 (E36)
    Last Post: 05-30-2006, 02:41 PM
  3. M3 front wheel bearings
    By cool99 in forum 1992 - 1999 M3 (E36)
    Last Post: 05-27-2006, 06:54 AM
  4. E36 M3 Rear Wheel Bearings -- Where to buy?
    By m3teknitian in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-14-2006, 12:44 PM
  5. Looking for: E36 M3 Front wheel Hubs and Spindles (king pins)
    By Rook in forum BMW Parts Wanted sponsored by Bavarian Auto Recycling
    Last Post: 11-04-2005, 12:48 AM
