Results 1 to 9 of 9
Thread: Headlight auto-level motor
    May 2018
    Florida
    '99 E39 M5T
    Has anyone had to replace the level motors, connected to the headlights? I picked up a spare set to practice rebuilding. Removed the motors and plugged them in to the car; they sound almost like a tattoo gun. Is that normal? I was trying to find replacements. The only thing I come accross is ebay, not sure if i trust used motors.
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    These are really simple to remove a few screws (3?) and the just pull out, AFTER you remove the head lamp assemblies from the car, which take 2 mins and 4x 8mm screws. I just replace the entire assemblies on my M5 garage queen. I will shift these over to the wagon.
    Current Garage Highlights
    2003 525iT TiSilver
    2002 M5 TiSilver
    Former Garage Highlights
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    1969 Road Runner 383
    May 2018
    Florida
    '99 E39 M5T
    Yup... I have a spare set of headlights (not installed in car). I disassembled over the weekend and connected the spare auto level motors to the car to test (before i submitted this thread). They made a noise, similar to a tattoo gun. That's why i started this thread... To find out if that is normal... If they will work... Or are they going bad? Lol. I tried to be as descriptive as possible, to hopefully get an answer. Sorry, if it's misleading.
    Thr headlights that are currently installed in the car, both have broken adjusters. And only one has a motor in it, disconnected. That is how they were when i bought the car. This is the reason i bought another set of headlights.
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    These are stepper motors which have 4 (?) separate windings that get pulsed with voltage. This makes them turn a specific amount of degrees per step. They operate this way to be able to control their position accurately.
    The motor that controls the throttle body is also a stepper motor.
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    Wagon727, Now I understand what you were asking about. When the motors are loose in you hand and they have no resistance to movement, they reach twitchy as they snap to the up positions. As long as they respond then they should be good to go. Some have discovered you do not need the adjuster motors after the adjuster mounts are broken. People just wire the lights in the up position. Another band aid/coat hanger solution. Having replace my H/L adjusters in a set of "unsaleable", the ship in a bottle approach, it is frustrating but the second unit will take you 60% less time. As long as your lenses are in good shape then fix them. Entire Hella replacements for angel eye and preface lift application can be ordered and the look will transform your vehicle.
    Link to vendors I have used: https://www.eeuroparts.com/Cars/BMW/...or-Electrical/
    https://www.rockauto.com/en/catalog/...assembly,10762
    2003 525iT TiSilver
    2002 M5 TiSilver
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    May 2018
    Florida
    '99 E39 M5T
    This is what's in the car now...
    This is what im working on, to put in...
    Edit - never mind, pic uploads do not want to co operate.
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    Yeah. I suspect a lot of headlight motor repairs are misdiagnosed busted-adjuster-mount problems. FWIW My front level sensor arm busted which was MY problem... I haven't had self-adjust headlights in years because that part turns out to be stupidly priced, and besides... not a real massively-missed feature anyway.
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
    May 2018
    Florida
    '99 E39 M5T
    So, it's safe to say, disconnecting the motors and relying solely on the manual adjusters will suffice? After 3 hours of tedious labor, I just completed replacing the adjusters in one headlamp. What a job.
    Mar 2010
    Oh yeah. I haven't had the auto-dippy things in years. Kinda miss the cute deluxe flash wiggle when I fire up the car but in no way does it affect my actual lighting.
    2003 M3CicM6 TiAg
    Former:
  1. E36 E36 zkw headlights/ brand new lenses/ auto level motors/ oem twist on connectors
    By M3nSD in forum Exterior Lighting & Body Parts
    Last Post: 07-21-2013, 10:11 PM
  2. Issue with headlight auto leveling after drop
    By 525iT_Feen in forum 1995 - 2001 (E38)
    Last Post: 05-09-2010, 12:23 PM
  3. E39 99 E39 OEM Hella xenon headlights auto level
    By ADOBO in forum Exterior Lighting & Body Parts
    Last Post: 12-11-2008, 03:48 PM
  4. LCM/LKM pin layout for xenon auto-level motor
    By Charlie587 in forum 1999 - 2006 (E46)
    Last Post: 06-29-2005, 09:26 AM
  5. Auto Level Motors
    By Charlie587 in forum BMW Parts For Sale
    Last Post: 12-14-2003, 05:15 PM
