Results 1 to 7 of 7
Thread: Steering lock/ignition problem
    Sep 2016
    Belgrade
    Sometimes I have a problem that they can not start the car with the key. Then I remove the key from the ignition, reinsert and then start it normally.
    Are you proposing that I replace only the ignition swith or full steering lock with cylindar, key and ignition switch ?
    Cheers.
    Dec 2012
    Grandview, MO
    1989 Bmw325IC
    How about trying an electric cleaner spray into the key/cylinder?
    Sep 2016
    Belgrade
    Quote Originally Posted by aaverhulst View Post
    Ok, I will try that!
    Thanks!
    Apr 2015
    Toronto
    e30s
    thing you can do is remove the steering column cover and clean the contacts on the ign switch. while in there you can check for possible broken wire. if that isn't the problem. would suggest getting a new coded key ordered from the dealership. After a while the key wears down and no longer match the tumber well.
    Sep 2016
    Belgrade
    Quote Originally Posted by Ceekers View Post
    This also came to my mind.
    Nov 2009
    Des Moines, IA
    90 ix, 91 i & ic, 02 325
    It could be just the "tumbler" - I changed one a few years ago - not too difficult.
    https://www.bavauto.com/bmw-ignition-switch-32321152474
    Sep 2016
    Belgrade
    Quote Originally Posted by 95BMWIC View Post
    I use Wurt contact spray and for now, it is ok. But, I'll follow state!
    Thanks for the advices!
  1. Steering Lock (Ignition Housing) Install Question
    By vypercat in forum 1991 - 1999 (E36)
    Last Post: 12-22-2013, 01:38 AM
  2. E36 E34 E32 E31 Steering lock, ignition lock housing NEW
    By Rigmaster in forum Interior Lighting & Body Parts
    Last Post: 04-19-2012, 01:35 PM
  3. Steering lock/ignition broken-Can't move
    By vet73 in forum 8 Series (E31)
    Last Post: 09-02-2010, 11:22 AM
  4. Good write-up on steering lock/ignition switch replacement
    By TheStigg in forum 1988 - 1996 (E34)
    Last Post: 03-20-2010, 04:41 PM
  5. Bad Luck again...Steering locked, ignition wont start
    By tokbandit in forum 1992 - 1999 M3 (E36)
    Last Post: 10-30-2009, 09:06 PM
