Is anyone familiar with using INPA ? Just purchased software and cables. installed, not communicating with car.
Only getting one solid black dot.
Does the key need to be on for the program to work ?
Any information on using the program ?
YouTube is your friend. Plenty of videos and write ups out there.
Yes, the key needs to be in position 2 to give the program something to see.
2001 | DINAN 7 Sport | S62 Swapped 6-Speed
DINAN Springs & Exhaust | 750 Brakes | M-Pars | Monsoons | NBT Nav/Radio
Dual Pane Glass | Black & Sand Int.
2001 | 750iL | AlpineWeiss III
@scotthduke on Instagram
Are you using the obd port in the car or the 21 pin under the hood ? and yes ignition to position 2 and mine only works if I have the ignition on to 2 then open inpa...........
Thanks for getting back to me. I am connecting with the vehicle both with the OBD in car and the under hood connector. I just don't know the steps for coding my DSC module.
I believe INPA is for diagnostic purposes only, not coding.
Current: 2007 Z4 M Coupe (blue/black)
Previous: 2001 740iL Sport (black/black), 2000 528i Sport (black/tan), 1995 318is (black/black), 1991 318is (white/black)
Thanks, I do have NCS. I guess I'll have to learn it. Any idea what it would cost to have a garage do coding?
If your DCS light is on you can find and clear the fault with INPA
E38 ABS Module coding is done through SSS Progman. Follow the below procedure
https://www.youtube.com/watch?v=vx8FwUCkHys
Some Places remain unknown because no one has ventured forth. Others remain so because no one has ever come back......
