Results 1 to 9 of 9
Thread: Inpa
    Feb 2009
    Olyphant, Pa
    2000 740i--944
    Inpa
    Is anyone familiar with using INPA ? Just purchased software and cables. installed, not communicating with car.
    Only getting one solid black dot.
    Does the key need to be on for the program to work ?
    Any information on using the program ?
    Mar 2011
    Greenville, NC
    2001 7-S62, 2002 X5 S2,
    YouTube is your friend. Plenty of videos and write ups out there.
    Yes, the key needs to be in position 2 to give the program something to see.
    2001 | DINAN 7 Sport | S62 Swapped 6-Speed
    DINAN Springs & Exhaust | 750 Brakes | M-Pars | Monsoons | NBT Nav/Radio
    Dual Pane Glass | Black & Sand Int.
    2001
    | 750iL | AlpineWeiss III
    @scotthduke on Instagram
    lA, ca, lA
    BLK 01 sp, 20 Trail Boss
    Are you using the obd port in the car or the 21 pin under the hood ? and yes ignition to position 2 and mine only works if I have the ignition on to 2 then open inpa...........
    Feb 2009
    Olyphant, Pa
    2000 740i--944
    Thanks for getting back to me. I am connecting with the vehicle both with the OBD in car and the under hood connector. I just don't know the steps for coding my DSC module.
    Oct 2013
    Louisa, VA
    2007 Z4 M Coupe
    I believe INPA is for diagnostic purposes only, not coding.
    Current: 2007 Z4 M Coupe (blue/black)
    Previous: 2001 740iL Sport (black/black), 2000 528i Sport (black/tan), 1995 318is (black/black), 1991 318is (white/black)
    Aug 2017
    Wayne,PA
    740iL (E38 '01)
    Quote Originally Posted by atr42nz View Post
    I think you need NCS for coding, though never done the DSC module
    Feb 2009
    Olyphant, Pa
    2000 740i--944
    Thanks, I do have NCS. I guess I'll have to learn it. Any idea what it would cost to have a garage do coding?
    lA, ca, lA
    If your DCS light is on you can find and clear the fault with INPA
    Jun 2008
    Atlanta, GA
    E53, E38, E34, E39T
    E38 ABS Module coding is done through SSS Progman. Follow the below procedure
    https://www.youtube.com/watch?v=vx8FwUCkHys
    Some Places remain unknown because no one has ventured forth. Others remain so because no one has ever come back......
  1. Settings in GT1/DIS to use the INPA Interface ?
    By MPower2007 in forum Diagnostic Software
    Last Post: 05-30-2018, 06:35 PM
  2. I'm starting a new Diagnostic forum about DIS, INPA, EDIABAS. Help me with its design
    By nuvola rossa in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 10-10-2007, 12:22 AM
  3. BMW INPA "interuption with interface"
    By kirbykirbykirby in forum Diagnostic Software
    Last Post: 09-02-2007, 11:47 AM
  4. EDIBAS INPA Software
    By Keith Nguyen in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-02-2007, 06:18 PM
  5. Anyone here no anything about INPA?
    By ZeroG in forum 1991 - 1999 (E36)
    Last Post: 02-12-2007, 01:39 AM
