RM European Auto Parts
Results 1 to 11 of 11
Thread: Should I do maintenance or wait for a new ECU
    Jun 2018
    Winnipeg
    2008 BMW 323i
    Moon Should I do maintenance or wait for a new ECU
    My 2008 323i is running pretty ruff, Engine light came on. So I bought coils, plugs, fuel filter, ect. Then my scanner arrived (came in the mail late) and it said it was the ECU. Part #7581123. I ordered new one (used). Now the engine light is off, should I wait to do the coils,or first the ECU. plus Where and how would I get it programed and or cloned, and tuned.
    Jul 2004
    Houston, TX
    36 Cylinders
    How did the scanner tell you it was the ecu? What codes?
    That model's ecu is notoriously difficult to program used.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Jun 2018
    Winnipeg
    2008 BMW 323i
    DME Digital motor electronics. sw -v7.7 / ss320815 / part number 7581123 / coding index 0c / diagnosis index 0000 / variant index 4D57 / hardware number 00 / date 04.09.2007
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    Phillip, if Abel (328 Power 04) tells you that your car's DME is notoriously difficult to clone....YOU NEED TO LISTEN !
    Abel is exceptionally proficient with all BMW computer issues. He has done absolutely magical things for me, and the shop I work for, virginizing used DMEs, including with cars newer than yours. If I knew that the computer were bad, and he told me what he just told you, I'd go ahead and order a new DME.
    That said, you didn't answer his question: Why do you think the DME is bad? What are the codes?
    Chris Powell
    BMWCCA 274412
    Jun 2018
    Winnipeg
    2008 BMW 323i
    DME Digital motor electronics. sw -v7.7 / ss320815 / part number 7581123 / coding index 0c / diagnosis index 0000 / variant index 4D57 / hardware number 00 / date 04.09.2007 I tried post a picture of it, but it was too huge
    Jul 2004
    Houston, TX
    36 Cylinders
    No picture needed.
    It's a Siemens/Continental MSV80 DME.
    VERY very difficult DME. I can clone them, but the process is not fun.
    Again, why do you think you need to replace it? Replacing the DME needs really solid proof. Most of the time, it's something else.
    -Abel
    Jun 2018
    Winnipeg
    2008 BMW 323i
    So maybe just do the coils and plugs, I get them on Tuesday. It does shake a lot when idling ,lacking power at higher rpm's and slower after 4500. Plus I get no warnings but almost feels like it's running hot. I got it in March and I love it but no one does a tune up before they sell a car. any suggestions? thanks for the help
    Dec 2013
    Chicagoland area
    EXOTICS
    I would go ahead and perform all the maintenance/items you have ordered,
    clear all codes, then complete a short drive cycle or until CEL appears.
    Perform new scan, then report back with actual codes or errors displayed.
    Btw, I hope you purchased something other than a generic OBD2 Scanner!
    Let us know the model you purchased.
    Jun 2002
    E39M5, E500 4WD
    You've said that your scanner "said it was the ECU". How exactly did it say that ? What were the codes, exactly? (In words, not numbers only)
    As Abel points out, the ECU is the very last suspect. I'd suspect that your code-reader is a useless OBD2 device, not a BMW specific diagnostic scanner. (For one thing, a BMW scan tool does not refer to an "ECU", because on a BMW, the engine computer is called a "DME".)
    Chris Powell
    BMWCCA 274412
    Jun 2018
    Winnipeg
    2008 BMW 323i
    Lol I really need to not think so negative, not the DME. Code are 2a87 exhaust vanos, and 2c73 o2 after cat converter. If I replace those two parts will I be home free?
    Dec 2013
    Chicagoland area
    EXOTICS
    I would remove and clean Vanos solenoids, with brake cleaner and compressed air if available.
    I would check O2 sensors wiring and connections, for cut/melted or corroded/loose/disconnected connections .
  1. Still waiting for oyur new bimmer?
    By sunra in forum Canada
    Last Post: 03-01-2006, 04:14 PM
  2. Replies: 10
    Last Post: 01-19-2006, 10:13 AM
  3. Rebuild and turbo the 3.2l or wait for the new M3
    By Excidium28 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 10-19-2005, 08:30 PM
  4. how long should u wait to get new tires? & michelin zero pressure tires, availability
    By Ridgeway in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 08-13-2005, 04:40 PM
  5. How long to wait before waxing new paint?
    By ss109 in forum Car Detailing and Show & Shine Prep sponsored by Autogeek.net
    Last Post: 02-23-2003, 01:36 PM
