Results 1 to 17 of 17
Thread: Right side vanos
    Jun 2017
    Kenosha, Wi
    99 540i
    Right side vanos
    I am having a issue with the venos bolt coming loose. We retighten it last night and I drove the car home for my cousin shop. This morning I fired it up to port in the driveway to wash it and notice that it wasn't running right once again so I shut it off. I pulled out the knock sensor stuck my finger in a hole and I could feel it that it came loose once again. Anybody have any of these issues before and how to fix it?
    Sent from my SM-J327T1 using Tapatalk
    Nov 2011
    Greedland
    99 540i6, 02 X5, Tundra
    What kind of torque wrench are you using?
    E85 fueled, Eaton m112 supercharged 4.5L M62TU, TTV racing flywheel, Spec stage 2+ clutch, 88c thermostat, eibach sway bars, wavetrac 3.15 lsd, m5 steering box, Quantum 340lph fuel pump, Dinan camber plates, some powerflex bushings, Supersprint headers, M5 cats, 2001 gas pedal upgrade and many other things done. all diy by me
    Jun 2017
    Kenosha, Wi
    99 540i
    Quote Originally Posted by 1999 540i m View Post
    All snap on., I have it all apart once again. Going to clean the parts and try a couple drops of red lock tight. It's left hand thread. So why is it coming lose, I am thinking it happens when I shut the car off. Do you have any other Solutions? Thank you
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    Knock sensor??? You can't get at those unless you remove the intake manifold.
    The vanos isn't held in with a bolt, it screws in.
    Are you talking about the cam sensor?
    Jun 2017
    Kenosha, Wi
    99 540i
    Yes, cam sensor
    Jun 2017
    Kenosha, Wi
    99 540i
    Quote Originally Posted by 99Bimmer540 View Post
    Yes, cam sensor
    So does the hex screw you screw in to lock the Vanos and then the nut locks everything in place? I'm trying to figure this issue out and if you give me any insight would be greatly appreciated. We tightened everything back up just as we did last night which the car ran perfect afterwards we did it just a little bit ago and now it backfired and won't start at all. Lost at this moment, think the Vanos hex screw stripped out?
    JimLev's Avatar
    Sundance Mesa, NM
    With the nut loose the center bolt will tighten the vanos unit to the cam.
    Then when that's done the nut will hold the trigger wheel in place.
    If either one was loose you'll need to retime the engine.
    Jun 2017
    Kenosha, Wi
    99 540i
    So in order to do that I have to tear the whole front of the motor apart right?
    JimLev's Avatar
    Sundance Mesa, NM
    Take off the bank2 upper timing cover, put the cam lock blocks on (crank at TDC), and just time that side.
    You may get lucky.
    Was the center torx bolt loose? If so you could have bent a few valves if you ran or tried to start the engine.
    Jun 2017
    Kenosha, Wi
    99 540i
    You may get lucky.
    What's the best way to go about tighten that Vino's bolt does the right side of the motor come apart by itself or does the whole thing come apart as a unit?
    Nov 2011
    Greedland
    Take the upper timing covers off, would be the next step
    Jun 2017
    Kenosha, Wi
    99 540i
    It's a 99 so does the covers come off separately on each side right-left , I'm going to run a digital scope down each cylinder to make sure I didn't score none of the Pistons before I do anything.
    JimLev's Avatar
    Sundance Mesa, NM
    Yes, each cover comes off separately.
    Doubt you'll see anything with a boroscope. Fix the timing and then see if it starts. If it doesn't check the compression. If a few cylinders are real low you bent some valves.
    Jan 2015
    Tempe, AZ
    1995 525i/5
    Those cam bolts have to be really clean— if you put in oily bolts that'll affect the torque values. I also torque the intake cam bolts to 90 ft/lbs instead of the factory 81 ft/lbs spec, as I once had the issue of the bolt coming loose and had to redo the timing (thankfully nothing went bad otherwise).
    1995 525i 5-speed - Thread
    JimLev's Avatar
    Sundance Mesa, NM
    Weird that the exhaust sprocket bolt get torqued more than the vanos (intake cam) bolt.
    I also torque the vanos bolt more too.
    Sep 2013
    Tx.
    02 bmw 540
    Funny second attempt for my timing while performing my guide install, I also noticed theVanos bolt seemed a bit loose, I also tightened it an additional 10 lbs of torque.
    Jun 2017
    Kenosha, Wi
    99 540i
    Quote Originally Posted by Mannyf540 View Post
    To give a update on the vanos situation, I found a 99 motor with 102,000 miles. Decided to just swap the motor..
  1. V1: Left or Right Side of Rear View Mirror?
    By JawKnee in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 06-21-2002, 10:39 AM
  2. WTB: Red/Clear Tailight (Right side) for e36 4dr sedan
    By Konstruktion in forum BMW Parts Wanted
    Last Post: 06-11-2002, 01:14 AM
  3. Right side Parking Light out!
    By BMWManiac in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-21-2002, 05:44 PM
  4. Ho you know if the spring is right side up?
    By Saul in forum 1992 - 1999 M3 (E36)
    Last Post: 11-16-2001, 04:31 PM
  5. For Sale: RIGHT SIDE E36 Headlamp Assembly
    By jrlombard in forum BMW Parts For Sale
    Last Post: 05-27-2001, 08:42 PM
