Buying parts to replace a timing belt/camshaft seal and this video I'm watching calls for this red o-ring that goes on around the camshaft seal. Anyone know what this part is called or the part #?
Sure,
Link the vid,
then we can all watch,see,
and identify the specific part you're referring too!
Yes, the part is called a cam flange O-ring, and they're almost always red in color. The part number is 11121265087. If you're tearing down far enough to do this O-ring (and you should), you also need the camshaft seal, which is part number 11121284154. Do NOT forget to loosen the Torx bolt holding the cam sprocket before loosening the belt.
1997 328i/4/5 - Cosmosschwarz Metallic on Dove Grey - Auto/Manual Swap - M3 Bilstein Sport/H&R Sports (95 M3 mounts) - Offset M3 LCAB - 20mm M3 rear sway bar - X-Brace - AA Tuning Strut Tower Bar - Rogue Engineering RSM - Dinan Cat-Back - 3.38 LSD - E46 330 front/328 rear brakes - SS Brake Lines - E36 fitment Style 42's (staggered) - M3 Front Bumper - M3 side moldings - M3 Rear Diffuser - DJ Auto Headlights (6k HIDS) - Frenched Fogs - OEM Clear Tails - E65 Rearview Mirror (Homelink controls + Autodim) - Alpine Type S Cabin Speakers (6x9 Retrofit) - 8" JVC woofer - Black Kidneys - Red Needles/Chrome Gauge Rings - OEM Alarm - Full Interior/Trunk LED Lighting - Mishimoto Full-Aluminum Radiator - More to Come!
