Results 1 to 4 of 4
Thread: 2001 Z3 Driver seat heater
    Jan 2005
    Wallingford, CT.
    2001 Z3 3.0i roadster
    While driving yesterday, I noticed my backside getting warm. It appeared that the driver seat heat was on. Both the low and high seat heater switches were off, but I depressed both of them to ensure they engaged and lit up when depressed. I turned them off, but my backside was still very warm. I felt the passenger seat and it was not warm. At that point, I am assuming a short in the ground for the driver seat wiring. Bently Manual shows it under the center console, but there are no pictures of the ground connection. Is there a wire connector under the center console similar to the connector under the seat and does anyone know which wire would be the driver seat heating wire?
    Feb 2016
    tempe, az
    1998 Z3M, 2006 330i
    Jan 2005
    Wallingford, CT.
    Quote Originally Posted by zellamay View Post
    I appreciate the link. It is showing the same component indicator and location as the Bently. Looks like I'll see how it is connected when I remove the center console.
    Dec 2007
    Great Dismal Swamp
    E36/7 E36/8x2 E46 F25
    Uhhhh, a ground wire that is permanently connected to ground can not short to ground, by definition. The heater are power switched. If one is on, it is likely a bad switch.Swap them and see what happens.
    /.randy
  1. Z3 E36/7 WTB rebuilt or new 2001 Z3 coupe seat motor
    By ross96 in forum BMW Parts Wanted
    Last Post: 10-14-2009, 08:19 AM
  2. 2000 528i - Driver seat heater
    By Georgetown528 in forum 1996 - 2003 (E39)
    Last Post: 11-10-2008, 12:52 PM
  3. WTB: Driver seat heater pads (NJ)
    By xcelerate in forum BMW Parts Wanted
    Last Post: 10-24-2008, 03:00 PM
  4. 1998 Z3 driver seat recline lever replacement
    By Austin2u in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 10-09-2008, 02:12 PM
  5. 2001 Z3 drivers side seat won't move up or down
    By mildbill1 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 09-26-2007, 06:08 PM
