My first question is: Is it an Allen wrench that suppose to be used in that hole? If not, what should be used (phillips, flat head..)?
If it is an Allen wrench, what size should it be. I've tried 4mm, 4.5mm, 5mm, 5.5mm, 6.5mm & 7mm with no luck.
Hi ... it's a 3 mm allen and it has to be pretty long. From memory it needs to be about 2.5 inches long just to reach the adjusting screw down inside the AFM plus whatever length handle makes it easy to use.
Cheers
hmm .. Wonder what happens if I do this ...
This is what you want IOT adjust your mixture:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
It's the right length.
