Results 1 to 6 of 6
Thread: loose plug in engine bay -- any guesses as to what it is?
    Nov 2010
    Los Angeles, CA
    1993 BMW 850 Ci
    While just giving the engine bay on my '93 850Ci an overall inspection, I noticed this plug was just dangling loose, and I have no idea what it plugs into. Was hoping someone here might know.
    It's attached to a single blue wire which leads up to a bunch of other cabling in a sheath that runs under the drivers' side MAF and adjacent tubing.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    the wire for the 2nd alternator for the exciter line. http://www.nationalmedia.biz/images/...fyThisWire.jpg
    http://www.bimmerboard.com/members/s...20iL%20016.jpg
    http://www.bimmerboard.com/members/s...20iL%20018.jpg
    On some built years that cable was pre-installed as standard, even when the engine does not have a 2nd alternator, like most E32 M70
    Sep 2010
    Corpus Christi Texas USA
    850ci, M5, Alpina B7
    It could be the wire that runs from the oil pan that measures quantity, the single wire that connects to the generator or the other oil pressure sending unit that has a two wire connector similar to a fuel injection connector.
    Jan 2005
    Japan
    Oil pan/oil level sensor is 2 wires, this is definitely the exciter wire for 2nd alternator, see my pics above
    Nov 2010
    Los Angeles, CA
    1993 BMW 850 Ci
    Quote Originally Posted by shogun View Post
    Many thanks for the info!
    Jan 2005
    Japan
    and the 2 wires from engine oil level sender have different colours, here pics from my site when we replaced the alternator cable and also repaired the plug with the 2 wires from oil level sensor + 1 wire as exciter cable from main alternator, that connector's wires are blue, and pink and brown
    http://twrite.org/shogunnew/fixes/electricalpower.html
  1. Leak / loose tube in engine bay? 2000 323i
    By drdavidge in forum 1999 - 2006 (E46)
    Last Post: 03-17-2012, 02:42 PM
  2. What is this loose plug in the engine bay? 1999 528iT
    By etcetera in forum 1996 - 2003 (E39)
    Last Post: 02-25-2010, 11:16 PM
  3. Black w/ red stripe plug in engine bay? What does it do?
    By fritzintn in forum 1992 - 1999 M3 (E36)
    Last Post: 01-06-2006, 05:06 PM
  4. Any Guesses on the Check Engine light
    By kadeer in forum 1992 - 1999 M3 (E36)
    Last Post: 06-26-2005, 02:34 AM
  5. Any tips for detailing engine bay?
    By JoeZ in forum Car Detailing and Show & Shine Prep sponsored by Autogeek.net
    Last Post: 06-08-2002, 08:10 AM
