Results 1 to 19 of 19
Thread: E46 318Ci (N46B20)
    Jun 2018
    Hungary
    E46 318Ci facelift
    E46 318Ci (N46B20)
    Hello to all,
    I would like to ask some note regarding my measurements. Is it normal ?
    If not what could be the problem ?
    https://ibb.co/mDBzn8
    https://ibb.co/cfNauo
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Welcome to the Forum!
    A large lack of data here. Showing a RPM vs as oxygen sensor doesn't tell me much.
    What is the car doing? Are you at normal operating temp? Do you have any codes?
    Lastly, you have a "Facelift", not a LCI.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    Jun 2018
    Hungary
    E46 318Ci facelift
    Hello Dworthy,
    thanks for your reply, I thoughg so its abbreviation is lci, but seems to be i was wrong.
    Yes, its at operation temperature. I have a feeling its consuption is a bit high, I know I drive in a city but 16l/100 km ,bit too much. I just had a trip, 120km, it was a bit more than 10L.
    O2S1 and MAF wad just replaced. ( at idle 1,75g/s)
    Jun 2018
    Hungary
    E46 318Ci facelift
    Jun 2018
    Hungary
    E46 318Ci facelift
    I am new to this forum, not really know how does it work. I have seen something that my reply is under moderation, but nothing happened up to now.
    Well, once again.
    Thanks for the feadback, my problem is that I have a feeling that the consuption of my car is high. In city 16L and just had a longer trip (out side of the city) 10L. O2 and MAF just recently replaced.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    As you are new to the forum, all posts up to 10 have to be approved manually by a moderator, that is the socalled spam-o-matic of the forum, just be patient.
    dworthy's Avatar
    Nov 2010
    Yes, for a 318i that is quite high for fuel consumption. So what else have you done from a maintenance standpoint? What is the KM stand? This can just be a bad oxygen sensor or perhaps a failing one, which should be changed around 160k km to 200k km.
    Also weak coils and old spark plugs can cause bad fuel mileage too.
    The LCI classification started with the E-6x cars, just like anything else names change, but it too means that the car is the "updated" version.
    Darin
    Current:
    Past:
    M-Flight Member
    Jun 2018
    Hungary
    E46 318Ci facelift
    I forgot to shaere one information : ~ 250 000 km
    dworthy's Avatar
    Nov 2010
    Do you know if the oxygen sensor(s) have been replaced? Most people will say that they are not going to replace them until you get a code, but why wait until it too late with a code?
    You are getting spikes in the oxygen sensors, so with that thought in mind, it can be several problems:
    1) Old sensors, taking too long to read/react
    2) Vacuum leaks
    3) Poorly tuned motor
    Darin
    Current:
    Past:
    M-Flight Member
    Jun 2018
    Hungary
    E46 318Ci facelift
    Hello
    Yes, just recently: upstream O2d, MAF, airfilter, the fuel filter ~2years ago and yesterday I cleaned the Vanos solenoids
    dworthy's Avatar
    Nov 2010
    Then start looking for intake leaks. Inspect the rubber boot between the MAF and throttle body. Also there will be a couple of other vacuum lines on that motor, check them out too. If any one of them is cracked from age, just replace it.
    Darin
    Current:
    Past:
    M-Flight Member
    Jun 2018
    Hungary
    E46 318Ci facelift
    Today I was parking while I made a short check.
    I hold it on a constant rpm then let it fall back to idle. Stft gone minus and plus as well. Is it normal or something wrong.
    https://image.ibb.co/magfBo/Screensh...708_192718.jpg
    https://ibb.co/dgiDxT
    Please check it and share your ideas.
    dworthy's Avatar
    Nov 2010
    The DME will always attempt to make the air/fuel ratio 14:1, or try to get as close as possible. What you are looking at is the STFT which means Short Term Fuel trim. That is nothing more than the injectors getting adjusted based on the inputs to the DME.
    So what brand of oxygen sensor did you install? It seems to be a bit slow on the adjustment, but that too can point to a vacuum leak in the system. So before I give you any more advise, confirm for me that the intake is sealed properly.
    Darin
    Current:
    Past:
    M-Flight Member
    Jun 2018
    Hungary
    E46 318Ci facelift
    skdenes said:
    Today 08:19 PM
    Hello again,
    As I have read, some told normal stft between +/-3%, others say +/-5%. Mine is a bit more, out of that range. What is strange for me ( but I am not an expert so may be that is normal). Take a look at 12:30, I released the gas pedal so RPM falls, but O2 says rich condition too much fuel, next time frame stft increased to 6%. Why?
    I used ELM327, maybe that is a shit, slow or lagging, so I will have soon K+D Can cable. Then I will repeate the measurement.
    Question, how to check the intake manifold ? Do u have some suggestions ? Thanks
    (O2 sensors are from BOSCH, brand new)
    dworthy's Avatar
    Nov 2010
    Sorry I missed your post.
    The best way to find a vacuum leak is to use a smoke machine. What it does is pressurize the intake and wisps of smoke come out where the leaks are. Once you get that checked, and more than likely you will find a hole or two, it should fix the rich problem.
    Darin
    Current:
    Past:
    M-Flight Member
    Jun 2018
    Hungary
    E46 318Ci facelift
    Hello,
    Sorry I am a bit also slow. I don't have so much knowledge about the cars nor stuffs to repair, but I am reading and checking youtube videos
    Well meanwhile my K+D Can cable had arrived. So I downloaded INPA and have seen the followings: (I hope I've attached thepictures)
    - big difference between actual/activation on inlet side
    - big difference between actual/activation on otlet side
    - adaptation is in the red zone.
    I've also red this post about the vanos :https://bimmerprofs.com/rough-run-vanos/
    If I am not mistaken and above mentioned "VANOS" and the my tab about "camsaft-position" is the same, than I have a problem or what is you opinion about it ?
    dworthy's Avatar
    Nov 2010
    Yes, that does look bad as what the DME is requesting, and what is actually going on is very different. Sadly the N4x motors tend to have problems with the VANOS at times. See if this works: Clear the adaptions and see if that helps.
    P.S. The VANOS on that motor is just an electric motor.
    Darin
    Current:
    Past:
    M-Flight Member
    Jun 2018
    Hungary
    E46 318Ci facelift
    Unfortunatelly with INPA I can delete simple adaptations like, lambda probe, or idle. I have not found a possibility to delete the adaptation of the camshaft. Nevertheless I used "delete all", but it stayed the same.
    dworthy's Avatar
    Nov 2010
    Okay, I would try to find a BMW shop who know that car and see what they can do or tell you about the VANOS.
    Darin
    Current:
    Past:
    M-Flight Member
  1. E46 318Ci idles high when cold
    By tokeeffe in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-29-2008, 11:07 AM
  2. e46 318ci - installing cruise control
    By Pete2007 in forum 1999 - 2006 (E46)
    Last Post: 12-23-2007, 02:27 PM
  3. e36 m3 or e46 328 into e46 318ci
    By rickgb in forum Engine Conversions
    Last Post: 07-27-2007, 02:36 PM
  4. Chipping a E46 318Ci Sport Convertible
    By mkuner in forum 1999 - 2006 (E46)
    Last Post: 07-18-2007, 09:47 AM
