Results 1 to 3 of 3
Thread: Coolant Hose from expansion tank to water pump
    Sep 2017
    Ontario
    1991 BMW 850I E31
    The hose that connects to the lower part of the expansion tank to the water pump was cut into by the belt. There is a small clamp that is around the hose that attaches to the engine (assuming to keep it away from the belt). Were is this loop supposed to be connected to and in what orientation bolt to the bottom or to the top.
    San Francisco, CA
    1972 3.0 CSi-1988 M6
    The coolant hose clamp/holder is attached as shown in pic #1. Pic #2 shows the 2 bolt threaded holes right above the ac pulley. The holder should be mounted to the upper bolt hole, the lower hole is for the belt tensioner mounting bracket. Hope this helps.
    Bert
    91 850i-A
    1972 3.5 CSi (L-jet, Getrag 265 5 speed)
    1988 ///M6
    2021 X3 M40i
    The back to back BIG COUPE” duo
    Sep 2017
    Ontario
    1991 BMW 850I E31
    Thank you, good to know i installed it correctly, I believe the new engine mounts some how changed the orientation of the hose which caused the belt to rub through it. Had to bend the bracket so the new one wouldn't rub as well. it was quite a messy clean up.
  1. Help with expansion tank to water pump hose E30 87 325is
    By magicpro33 in forum 1983 - 1991 (E30)
    Last Post: 03-22-2018, 08:25 AM
  2. Leaking coolant. Hose or expansion tank?
    By hkovacs94 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-03-2015, 01:03 AM
  3. Help! Coolant leak from expansion tank to water pump
    By Jared9392 in forum 1996 - 2003 (E39)
    Last Post: 05-13-2012, 08:15 PM
  4. Flexible water hose to expansion tank
    By Beemerism in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 03-05-2012, 11:16 PM
  5. FS: e36 coolant overflow reservoir/ expansion tank w/ cap, level sensor, hose
    By sweet e36 pimp in forum Engines, Performance Parts & Software
    Last Post: 05-31-2009, 07:02 PM
