Results 1 to 4 of 4
Thread: Best Window Regulator Replacement
    Sunland, CA
    2003 540i M-Sport
    Hi, I have a 2003 540i M-Sport that I replaced the right rear window regulator only with the following for $33.45 in July 2017. I am needing to replace it again and was wondering if anyone had a recommendation of a better brand / manufacturer of the part.
    Passengers Rear Power Window Lift Regulator Replacement for BMW 51358252430
    Sold by: EverydayAutoParts
    Dec 2009
    Annapolis, MD, USA
    2012 JSW 2.5
    Your best bet is to buy it from FCPEuro.com because they provide a lifetime warranty. A stick and some duct tape does a good job of holding the window up while you wait for parts.
    Aside from the bad design, the degradation and contamination of the window guides and seals will increase the resistance on the window and contribute to the failure. If you have or had tinted windows, the residue from the glue makes matters worse.
    When you remove the glass to replace the regulator, clean the glass thoroughly. I use 0000 steel wool and glass cleaner. Then move the window up and down manually to check for drag. Clean the guides and seals where necessary. Use a soapy water or another rubber-safe cleaner and don't rub too hard. There will come a time when the guides and seals deteriorate to the point where nothing can help them and replacement will be the only way to get your windows sliding smoothly again.
    [IMG][/IMG]
    Los Angeles, CA
    Formerly 03' 540i
    Fronts: Original BMW only, I've tried a few aftermarket and they either failure shortly after or refuse to install/work properly. OEM is drop in once and DONE.
    Rears: Can go a few ways. Design is easier I guess. I've have good luck with URO's.
    2003 BMW 540i [Sterling Gray / Gray]
    [Msport] [Mods from A-Z] [Two-Tone Interior]
    Stuff For Sale :
    All types of E39 OEM Used HVAC Buttons
    Other E39 Parts, see my ebay! [Click]
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    I'm dreading the fact tath both my fronts are on borrowed time... already clickety-noising when the window goes all the way to the bottom... I probably jinxed myself just posting this now... So OEM $$$ is the only way to go, eh? That blwz but I can imagine it bein the case.
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
  1. Window Regulator Replaced, Air Bag Sensor
    By 32CJONES in forum 1999 - 2006 (E46)
    Last Post: 04-07-2007, 11:04 AM
  2. Window Regulator Replaced, Window Juddery
    By Klint in forum 1991 - 1999 (E36)
    Last Post: 01-22-2007, 02:47 PM
  3. Driver's Door Window Regulator Replacement?
    By Hotswimmer in forum 1996 - 2003 (E39)
    Last Post: 10-16-2006, 11:05 PM
  4. Quick window regulator replacement detail questions
    By Papa316Smurf in forum 1991 - 1999 (E36)
    Last Post: 04-30-2006, 02:02 PM
  5. E34 Window Regulator Replacement
    By StorminNorm in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 12-04-2005, 12:14 PM
