Results 1 to 3 of 3
Thread: Z3 freon leaks - shrader valves
    Chicago, IL
    '09 X6 - '04 745Li
    I've discovered that my LOW PRESSURE shrader valve appears to be leaking. The valve looks like it can be replaced in it's entirety from the line, I could be mistaken.
    what is the normal process for repair, is the internal stem and o-rings only replaced?
    realoem.com shows the following part numbers and would like someone to confirm
    64-50-9-177-577 and 64-50-9-177-576
    Thank You
    '09 X6
    '04 745Li
    '97 Z3 1.9L
    '94 740iL
    '88 528e
    '94 Jaguar XJS
    '85 MB 380SL
    May 2012
    USA
    2000 BMW Z3 2.3 Auto
    I replaced both of them (high and low) based on real oem. Did the whole thing (like the part number you provided). Not internal parts. Had to replace all the parts of the AC except the lines. Evaporator, condensor and shrader valves were leaking. Compressor was weak
    The refrigerant + Pag oil have dye in it. So before you start working on it, check all the joints, condensor, compressor area and if possible, the evaporator (from the side) to see any leak. Doing all at once is easy. If you are replacing any parts, make sure you are using the right O-Rings
    Los Gatos CA
    1987 325is, e34, Z3, e39
    There is a very clever device which lets you change the schrader valve without discharging the system. They are $20-$50, depending on the quality you want.
  1. Z3 coolant leak
    By JeffreyD in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 05-08-2020, 01:34 PM
  2. Invisible AC freon leak?
    By oraph in forum 1991 - 1999 (E36)
    Last Post: 10-09-2008, 02:53 AM
  3. Oil leak around valve cover gasket
    By trimegatron in forum 1992 - 1999 M3 (E36)
    Last Post: 07-28-2007, 10:42 PM
  4. Maval Z3 Rack leaking after 20K
    By aespen in forum 1992 - 1999 M3 (E36)
    Last Post: 09-13-2006, 10:26 PM
  5. Z3 top leak.
    By stjobs in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-19-2002, 08:32 AM
