Bavarian Soundwerks
Results 1 to 6 of 6
Thread: Will this radio work?
    Jun 2018
    Arizona
    1997 BMW 528i
    I found this radio on amazon but I have no idea what Iím doing. I have no idea if this even fits or would work? I just want a simple cheap Bluetooth radio so I can use Spotify on my phone. I donít want to spend like 300 dollars on a touchscreen unit either. Would this be a simple plug in and go or would I need a different wiring harness or something? Does it even fit? If it is completely the wrong thing would you recommend what I could do, thanks. Itís going to be going into a 1997 528i let me know if you need anymore info.
    https://www.amazon.com/dp/B01CG8N0H8..._Db1kBb7R16P26
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Donít waste your money on crap like that. Spend $100-$150 on a quality Alpine or Pioneer head unit. Be advised that you car likely has a separate amp in the trunk. The interface between the factory head unit and the factory amp could be balanced differential signaling. If it is your head unit options will be more complicated.
    Jun 2018
    Arizona
    1997 BMW 528i
    Could you link what you would recommend? Is there a name for the size of the radio or type of head unit it would need?
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    The head unit in your car is DIN sized. That is, itís dimensions meet the DIN dimensions standard. Thanks means any head unit that meets the DIN dimensions standards will fit. Figure out what features you need to narrow down potential models. Then go to a store that sells the brands to check out functionality and looks. Buy what trips your trigger.
    Jun 2018
    Arizona
    1997 BMW 528i
    Would the wiring be a simple plug in and go job or would I need change that too?
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    It depends on the manufacturer. At the least youíll need a wiring harness adapter that new head unit plugs into. Check www.crutchfield.com.
  1. radio works when it wants too !
    By Sleuth in forum 1996 - 2003 (E39)
    Last Post: 07-10-2006, 07:34 PM
  2. Alpine 7894 CD audio won't work but it reads the CD fine. Radio works fine
    By BMW318Guy in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 02-06-2004, 09:49 PM
  3. Radio works...but no sound
    By SG_M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 11-11-2003, 02:05 PM
  4. Would C43 radio work w/my 97 328i
    By glyboual in forum 1992 - 1999 M3 (E36)
    Last Post: 10-11-2003, 12:03 AM
  5. why doesn't radio work?
    By Guillermo in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 08-11-2001, 10:51 PM
