Results 1 to 16 of 16
Thread: Retrofit "Sport" Button from M5 onto 530i? [Also Instrument Cluster Dead Pixels]
    Jun 2017
    Chicago
    2003 BMW 530i M Sport
    Does anybody know if it's possible / if it would work to some how retrofit the sport button onto a 530i? Every time I try to google it, I just get a million results about the E60 5 series having a hidden sport mode...
    Also, I need to repair the instrument cluster pixels very badly, and I know I need the one large ribbon cable, but it's not just the OBC that's messed up, the mileage thing is like super dark and hard to read, is that a bulb that needs replacing or will the new ribbon cable fix that too?
    Also, currently my brake pedal pretty much stops halfway, and then if you push really hard past that, it's like pulling the handbrake up and it stops instantly, the ABS trifecta is happening at the same time too, is this the reason or do you guys think there might be an issue with the master cylinder / brake booster? The only ABS code I've got as well is for a brake pressure sensor at the moment.
    Thanks guys!
    Feb 2014
    Caboolture, Q, Australia
    E39 535i
    Can't say I've heard of that option. It's a completely different DME
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Quote Originally Posted by 1823alex View Post
    Not possible without a completely custom ECU tune. The sport button just modifies the throttle mapping on the M5, so if you do a Shark Injector tune on a 530i you have a basically permanent Sport mode.
    I have the Shark Injector tune, btw. If anyone is curious about the raw data and can figure out how to tune their own MS43 DME, I’m not opposed to sending the file along.
    Pixel repair is a PITA. Unless you have immense patience and the steady hands and eyesight of a watchmaker, I recommend having someone who has done the repair many times do it for you. Forum member blackknight530i runs a business called “Fixels” (check them out on Facebook).
    Thanks guys!
    Are you scanning with INPA (or similar), or a generic scanner? Brake pressure sensor failures are rare, but possible. But you need to do some digging (i.e., googling).
    Nate J.
    (oOO\ (|||)º(|||) /OOo)
    (eŌō\ (||||)º(||||) / ōŌe)
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Generally, a hard to depress brake pedal is a sign that the brake booster has failed or is failing. Obviously, have a good look around your brake system to ensure that there are no imminent mechanical disasters. You could have a leaky brake hose somewhere, which is extremely dangerous.
    Also, check the area under the driver’s side cabin air filter housing for water and leaf debris. If the area where the brake booster sits gets filled with water because the drains are blocked with leaves and other rubbish, it can ruin the brake booster and even hydro lock the engine.
    Nate J.
    Jun 2017
    Chicago
    Quote Originally Posted by computiNATEor View Post
    > I'll probably try it myself cause I'm cheap.
    > I wasn't using INPA but I was using BMW Scanner 1.4.0 which gives you errors from each different ECU of the car and lets you code simple stuff. I cleared all the codes on it but wrote down what they were first, so I'll have to see if they come back. However prior to when I drove the car, I did open the brake fluid reservoir since I got another code for brake fluid level, and it was above max so I siphoned some of the brake fluid out and it looked pretty normal to me. Could the loss of pressurization cause that though? Cause wouldn't driving the car around the block after that fix the pressurization or does it take longer?
    I'll take a look around the brake booster / reservoir area later today and report back w/ pics if I see something.
    Jun 2017
    Chicago
    Update: the ABS issue error went from the brake pressure sensor to "108 - SN Control" & still a steering angle sensor and "Watchdog"
    Anybody know what SN control is?
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Nope. It would seem to be a rare code. However, do the standard wheel speed sensor check to make sure you don’t have a bad sensor causing problems.
    I’m not sure the hard brake pedal and ABS errors are exactly related or if they're two separate problems.
    The fluid level in the in the brake reservoir should be pretty high. As long as it’s not spilling over when the cap and level sensor are put in.
    Have you replaced any modules lately? That’s the only info I see online related to this error.
    You our can try to recalibrate the steering angle sensor with PASoft (aka BMW scanner 1.4)
    Nate J.
    Jun 2017
    Chicago
    The fluid level was far past the "Max Fill Line" or whatever it was.
    Haven't replaced any modules, it's a brand new car (to me) and I'm the 3rd owner and the owner before me did pretty much 0 work to the car...
    How do I go about recalibrating the steering angle sensor? I do have that error as well. I don't have any wheel speed sensor errors, and every time I've had I've gotten an error on PASoft / BMW Scanner 1.4.0 on my 525i.
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    I thought there was a recalibrate button or something. Maybe that was in INPA.
    Nate J.
    Feb 2014
    Alexandria, VA
    ‘01 540’00 528T’03 525T
    I had a bad steering angular sensor, potentiometer was worn out in the center position. My SnapOn SOLUS saw it, it let me reset it, but as soon as you turned the wheel to the right, it would go from 0, 1 degree, 3 degrees, 5 degrees.... it was shot, you reset it, as soon as you turn to the right, the traction control light lit up. Got a new sensor, all was good.
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    LOL. Yeah. The MS43 DME isn't going to have an input nor the code to process a sport-button-press. It has no way of knowing what a sport button is. The idea that you can install the button and have sport mode is pretty funny (sorry)..
    Would take some real assembly code hacking to create a sport-mode button for the MS43 DME.
    Pssst Hey Nate... "yer not supposed to say that out loud"
    (although with how he did the whole "SharkEdit" bait and switch vaporware, I have very little sympathy for Jim Conforti... Lotta guys bought Shart-Tunes back then based on idea it was coming out... Turner even sold USB cables to buyers of Shart-Tunes with the promise that "ShartEdit will be here soon!" for quite a while back in the day... then eventually had to let people know "errr no he's never gonna do that...")
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
    Feb 2014
    Alexandria, VA
    Install the button anyway, your butt dyno might make your brain think that you are in sport mode...
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Daniel F over on E46Fanatics is really working hard to create an actual tune for the MS43 cars that will allow things like ignition cut launch control, no lift shifting, and a whole bunch more. You can see where he’s at on MS43wiki.com. So who knows, it might be possible one day to have a functional Sport mode button.
    I can tell you exactly what a Shark tune does: it hurries the electronic throttle mapping, which is annoying in traffic. It adds timing to a dozen or so ignition timing maps, but it does so by simply scaling the maps up by 10% or so.
    And that’s it. The more aggressive throttle and increased timing (hence why 91 octane is required) do make the car feel significantly more torquey, but other than that, it’s not much of a tune.
    Nate J.
    Philadelphia, PA
    2005 M3 & 2004 330i
    I suppose it could be done if you retrofitted an MS45... but that's a lot of effort for relatively little gain.
    You can do what some of the E46 guys do and connect the sport button to a sprint booster.
    Aug 2016
    Palos,illinois
    2001 540i
    A guy in the northwest suburbs of Chicago sells the pixel repair cable on eBay. He also replaces them. Did mine while I waited. Took him about an hour and it is perfect. Yes, the mileage display is part of it. I didn’t want to risk having the cluster damaged or lost is shipping because that would be an incredible pain in the ass.
    Jun 2017
    Chicago
    Where in the NW Subs? Can you pass along his info & how much does he charge?
  1. E34 FS: 1991 BMW M5 All Working Odometer Instrumental Cluster 97,879 miles WHITE Back
    By IrfanM in forum E34 Classifieds (closing soon)
    Last Post: 09-27-2015, 06:47 PM
  2. E39 ///M5 Instrument Cluster - ALL pixels working
    By russap5 in forum Exterior Lighting & Body Parts
    Last Post: 03-04-2010, 08:31 PM
  3. M5 parts for sale instrument cluster and shifter console
    By h2oplaydamian in forum 1988 - 1996 (E34)
    Last Post: 11-10-2008, 12:44 PM
  4. e34 m5 instrument cluster dead
    By allill in forum 1988 - 1996 (E34)
    Last Post: 06-08-2006, 12:06 PM
  5. Replies: 1
    Last Post: 06-28-2002, 08:52 PM
