Results 1 to 22 of 22
Thread: former Lurker, 80 733i
    Jun 2018
    MT View, HI
    98 318ti, 80 733, 76 '02
    Hello All,
    About time to post so I can thanks all you for the unknowing help. What a great resource.
    Bought an 80 733i back in February. Fairly low miles, base model (read no power seats). 3.2 auto. Originally dark braun met, but now a gold color. 2 tone interior, beige and chocolate. Hadn't been driven in about 7 years. Po had died. New lines, pump, and filters and it fired up. Drove it home, but it idled badly. I've now got all intake gaskets, new injectors, and other small service parts. Had to order another manifold (#123) as the injector bolt was snapped off. While I'm waiting for that tto arrive from the motherland, I chanced across an 89 635csi parts car. Cool, I can do the 3.5/Motronic upgrade I read about here. Turns out the timimg chain was snapped, and all the pistons have been kissed by the valves. Oh well. Back to plan 1. At least the 6er gave me an 3.73 LSD diff. Thanks to this board, I'm also waiting on a case cover with upgraded bolts and new seals for it.
    Attatched pics of the machine.
    Thanks for having me.
    Jun 2010
    TX
    1983/84/85 745i
    Thumbs up
    Hit up Kojo on here, he has an early car and it had similar running issues. My speciality are the turbo cars, so I am not of much help. Sorry.
    Welcome aboard!
    I make E23 parts.
    10/1984 745i
    11/1984 745i
    11/1984 735i (10:1-265/6)
    Jun 2018
    MT View, HI
    Thanks for the welcome. This wasn't a plea for help as much as a thanks for all the information available on this site.
    I believe the injectors will fix most of idling issues. After that, time to tackle the A/C.
    Dec 2009
    Seattle, Washington
    E23 E24 euros E34 E38
    Welcome
    Sent from my HTC6545LVW using Tapatalk
    Jun 2018
    MT View, HI
    So turns out the e24 3.73 lsd is a medium case. My 733 is running a large case. I thought I was going to have to sell the med. case, but read in a recent thread that putting it in my ride is no big deal. I tried the search function, but my input must be bad.
    My concerns are:
    ) the driveshaft. Wouldn't it have to be lengthened?
    ) the cover. Is the sizing different between the two? Or will the e24 cover mount to my e23? looks the same, but I don't have them side x side yet.
    Anything else I'm missing?
    Feb 2009
    Pittsburgh, PA
    '86 635CSi, '08 128i
    Sounds like you're making great progress... However, the diff cover swap won't work for you. The medium case rear cover is slightly too short to fit onto the large case. The E24 rear mount is a little different too...IIRC the really late E24 was offset instead of centered.
    Jun 2018
    MT View, HI
    NA
    Jun 2018
    MT View, HI
    road worthy
    Been a little bit since my last update. Finally got the manifold, new injectors, and the 3.73 installed. Had to elongate the holes in the subframe a bit. While I was in there, new hoses, water pump, Euro headlights (of sorts), and 16" rims and tires. It's also legal and running down the road as of November.
    Reason for the update is I also upgraded the tail and brake lights.
    Above is the tails, left is stock, right is upgraded. Below is brakes, Same spiel.
    Ended up using 6 '80's GM 1157 holders. I know, I know, but it's period correct. And I'm so much more visible.
    Next up is to change the brake accumulator, and then the "740 rear brake" upgrade. Also have some lowering springs in the works, but I need to order the proper suspension pieces.
    Thanks for all the advice, both directly and indirectly!
    May 2010
    Tangent Oregon
    79' 320i 84' 733i
    Dec 2005
    Omaha NE
    84' 533i Turbo
    Looking good!
    How did you do the tail light conversion?
    Jun 2018
    MT View, HI
    Quote Originally Posted by StevenHenriksen View Post
    I like the interior color combo
    Yes, It's very interesting. Even the console is dark brown.
    Quote Originally Posted by gixxerboy View Post
    As for the process, I only took a couple pics. Pretty simple. It does modify the bulb housing, so if your a purist, turn away now. I bought a half dozen bulb GM style sockets off eBay. Part number was 7528. I liked these ones as they had a flat back side.
    To start, I pulled the little brass tabs for the existing brake and tail lights. Just a couple tabs on my pre-facelift model. I cut those pieces loose but left the wires to solder to. you can see the squares in the empty socket, these are perfect for the new socket.
    Then come the drilling. I used a 1 inch bit as I don't have a good assortment of metric drills. I drilled three holes so the light value has tripled. I'm ashamed to post the finished product, but it holds the bulb socket perfectly.
    Then I soldered the wires to their proper colors (don't forget the heat shrink) and twisted the sockets in place. They lock down with a 1/4 turn. A little cloth tape over the wires and they tuck nicely under the factory covers.
    I realize they cannot be returned to stock, but I have the originals to my car safely tucked away!
    Jun 2018
    MT View, HI
    latest pic
    Realized I don't have a pic with the Headlights or the 16's
    Jul 2010
    Leland, NC
    85 €735i 08 550i/6
    Nice 2002
    Sent from my LGLS755 using Tapatalk
    Mar 2013
    USA
    E21/early e23/e34
    James, looks good, can't wait to see what else you do to it!!! And that 02... looks really nice too.
    May 2010
    Tangent Oregon
    79' 320i 84' 733i
    Nice collection you have there! I might have some lowering springs and old bilsteins available pretty soon if you are in the market.
    Jun 2018
    MT View, HI
    Mahalo All
    The 2002 (Gretta) is why I bought the 733i. Needed a car to cruise while I put her out of commission. It's about there, but there's an m90 on the BigCoupe forum that's tempting me. Fortunately, I'm not a member there.
    Gretta's planned repairs are a couple bad spots on the passenger floor, headliner, dash refurb, a few oil leaks, and add AC. Been collecting parts for a bit. The previous owner loved the little lady, so she has some nice upgrades.
    Mar 2019
    San Rafael, CA, USA
    1983 E23 733i
    If TowJamma doesn't need the suspension parts I would be very interested. I'm getting an '83 733i back on its feet and suspension is next on my list.
    Jun 2018
    MT View, HI
    Another update. Sent the vin into BMW archives. Got this.
    Dear Sir,
    Thank you for your email.
    The BMW 733i US VIN 7360302 was manufactured in December 1979. Further details are not known, because the delivery records are not complete anymore.
    Maybe you are lucky and able to find the so called "Laufzettel" under the rear seat bench (where the colours and options are coded). Then you can send us a picture of the "Laufzettel" and we will check the options lists for more information. If the Laufzettel isn't there anymore, please contact us again. We could try to find out at least the original colour via the inspection card.
    Nevertheless we hope this information is helpful for you.
    Yours sincerely,
    Julia Oberndörfer
    Well, I have the Laufzettel, so I sent her pics. Got this
    Dear Sir,
    Thank you for your reply.
    This is the decoding of the "Laufzettel":
    Kundennr. 0004 - Customer number: importer BMW of North America
    Farbe 154 - original colour Brasilbraun metallic, paint code 154
    Polster 0110 - upholstery Leather Parchment
    44.5 - radio preparation
    60.2 - automatic cruise control
    75.8 - maker's plate
    We hope this is helpful for you.
    Yours sincerely,
    Julia Oberndörfer
    What a great service. I was trying to look up codes myself, but everything came back as S or U codes.
    Talk about a minimaly optioned 7. I understand US bound 7er's were fairly well loaded to start. I have leather, sunroof, power windows, etc., but Cruise...
    Jun 2018
    MT View, HI
    another leak
    I have also been fighting a leak that fills up my passenger rear floor. Trunk is dry. Headliner is dry. car is nearly rust free. I did a lot of web searching and scouring the car in the recommended places. I have the plug and carpet padding out of the rear floor area to facilitate drainage.
    Not nearly rust free as I thought. I pulled the Hofmeister kink trim, and wow. There it is. That will let some rain in. Especially as we live in the land of rain.
    As soon as I finish playing with the 2002, I've some welding to do. That would also be a good time to install the wide band sensor.
    Jun 2018
    MT View, HI
    bumper conversion
    Found a little time (while waitng for the 02 parts) to install a euro rear bumper. Don't have the lower pan, but white jaguar on my e28 dotcom sells a nice looking fiberglass one. Price isn't bad for being shipped from Russia. Get it here and get in in paint, yum.
    Also needing the side trim if anyone has a spare or two for sale... Come on, it's worth a try.
    Jun 2018
    MT View, HI
    A couple years since an update. Just been driving around once a week. Dreaming of a motor upgrade. That poor 80's smogged, low compression, 3.2. Then a motor showed up on craigslist. Couldn't resist. Had to buy the whole car, but that just means I have (most) everything for the swap. It is an 06 m3, 94k miles, salvage title, and the SMG is acting up. Runs and drives.
    Thoughts? Suggestions? Am I crazy? They are putting these in e30s, so...
    May 2010
    Tangent Oregon
    79' 320i 84' 733i
    An S54 in an E23 would be fun, I don't think I have seen that done yet! They have been swapped into E30's, E21's, and E28's quite a bit, so there should be a lot of helpful info available as far as wiring transmission fitment. Also, glad to see you still enjoying the 733. I forgot what an interesting color it is, I like it a lot.
  1. '80 733i parts or whole thing
    By GTClarke in forum Whole Parts Cars
    Last Post: 05-03-2009, 10:44 PM
  2. WTB: '80-'81 733i parts car
    By ava in forum BMW Cars For Sale / Wanted
    Last Post: 08-17-2006, 03:58 PM
  3. Vibrating between 80 and 90 mph
    By QuestMCoupe in forum 1991 - 1999 (E36)
    Last Post: 04-21-2001, 07:44 PM
  4. Another cloudless 80+ day here in Palm Beach:)
    By Andrew 97M3 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 03-02-2001, 11:20 AM
  5. I like how it was .. Gold is so 80's
    By BLOWN///M COMPACT in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 02-26-2001, 10:00 PM
