Greetings everyone,
I am undertaking the challange of swapping a sedan dash into the ti. I aquired a 1996 328 with a clean interior and questionable engine for $500. Ill be swapping it into my 3rd ti, avus blue cali top also with questionable engine. Ill post photos as I progress.
1999 Dakar m3 Vert, 98 Alaska blue cali m318ti, avus ti sport cali (dash swap), 95 318ti white base model.
First things first, I need to strip the TI and sedan
20180602_094410.jpg20180620_185341.jpg20180623_105810.jpg20180623_111905.jpg20180623_134622.jpg
I have to swap the havac unit before putting in the dash.
I have the dash inplace and powered up the ac system. The wiring for 16 button is still in the works, theres quite a bit of wiring and much of it doesnt plug and play with the ti harness. Once the weather cools down ill connect as many sensors and switches possible.
Fitting the center console and near foot well dash pieces required removing some brackets. I simply just cut then out with a dremmel.
Notes
Connecting the OBC to the ti wiring has been quite annoying, still have four more wires to figure out before its fully setup or setup as far as I can go.
To power the system the Ti harness wire color is Violet-yellow and the sedan is violet-white
Glove box light is also slightly different, Violet-white to Violet black.
Thats pretty awesome. Are you swapping the m52 also? Is the blue ti obd1 or obd2?
Current lineup: 99 BMW M3vert (project) , 05 Mazda RX-8, 04 Mercedes CLK320, 03 Chevy Express 1500 (work van).
Previous rides: 07 Mazda RX-8, 92 BMW 325iNV, 94 BMW 325iC, 94 BMW 325i S50 M3 clone, 84 Mitsubishi Cordia Turbo, 84 Mazda B2000 lowrider, 88 Toyota Tercel, 88 Honda Accord, 93 BMW 318i, 95 Nissan Altima, 89 Toyota Camry, 95 Mitsubishi Eclipse GS-T, 93 BMW 318is, 84 Toyota Tercel, 96 Mitsubishi Eclipse GS-T, 97 BMW 528i 1JZ swap, 94 Acura Integra 4dr, 88 Toyota Corolla Wagon, 97 VW Jetta GLS, 86 Toyota Corolla AE86 4A-GZE supercharged engine swap, 94 Lexus LS400, 95 Isuzu NPR Turbo, 01 Suzuki TL1000R, 98 Honda CBR600F3, 99 Yamaha R6 and countless other dirt bikes and toys
I don't plan on swapping the engine and its OBD2, this car will be driven by my girlfriend once its all done. My eyes are set on a Porsche.
