Results 1 to 4 of 4
Thread: Coupe rear hatch release
    Jul 2010
    Philadelphia, PA, USA
    2001 M Coupe, 2002 M3
    I've read about how the rear hatch release actuator tends to fail over time. I tried putting more tension on the metal piece with a slight bend, but lately, it's acting up again.
    Can anyone tell me if replacing the actuator will make it work more consistently? Sometimes, I have to push the button four or five times to get the hatch to open. It's times like these that I wish it had a much simpler, mechanical lock, like an old fashioned trunk lock.
    May 2009
    Austin, TX
    99 M Coupe
    I might be able to answer that question over the next couple of months. I've had a ton of fun with my hatch, which began when it simply refused to unlock with either the key or a button-push. A rather painful investigation (it involved crawling over the bulkhead and removing a lot of trim) revealed that a wee plastic bit of the locking mechanism had become embrittled and had broken. making it impossible for either the key or the actuator to open the hatch. I repaired the plastic bit (I really should write that up sometime), put it all back together, and all worked great - for a few months.
    Now, it SOMETIMES opens with a button-push, and ALWAYS opens with the key.
    Either the actuator is cranky, or my repair somehow occasionally gets misaligned. I figured it would be good to have the new actuator on hand regardless; so I just ordered one. When time permits, I'll take the whole mess apart again, and see what it'll take to fix it on
    Greenville, SC
    Several
    I gave up on the push button working with any reliability long ago and just open with key all the time. Works great, 100%. Forgot what I disconnected, but it's simple and removes the annoyance of push not working.
    "If the Corvette is a rebellious child of the extended automotive family, the M coupe is the blackest of sheep." - via Car & Driver
    Jul 2010
    Quote Originally Posted by adonnan View Post
    That's actually good to know- I think if I disconnect the actuator rod, it will prevent the push button from working, but if the key will mechanically open the hatch, then I'm not too worried. Thanks!
  1. Coupe rear hatch lock actuator
    By Wrench Turner in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 06-17-2018, 08:19 PM
  2. Replies: 4
    Last Post: 04-11-2014, 09:18 AM
  3. Coupe Hatch Release
    By Mach Tuck in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 05-02-2013, 06:20 PM
  4. Replies: 10
    Last Post: 07-14-2011, 10:39 PM
  5. '99 528iT - rear hatch release issue
    By CoopInGa in forum 1996 - 2003 (E39)
    Last Post: 08-21-2006, 05:29 PM
