SOLD
I have a megasquirt I rescued off ebay a couple years ago. I was going to use it in my car but I got a MS3 pro ultimate to use instead. The previous owner had put about half of it together but never finished it. I went through the whole board and desoldered everything and resoldered all the connections. I also verified every resistor and diode on the board with a multimeter. This is a V3.0 main board with the MS3 daughter card and MS3x expansion board. I was going to turn it on and put a base tune on it but I can't find the tuning cable that came with it. I am selling it cheap since I have not tested it and I cannot offer tech support on it, so I am selling it as is. Will need to get a tuning cable and a wiring harness from DIYautotune.
Price is $350 shipped
This kit from diyautotune is $405 for the MS3+ $110 for the MS3x expansion board, or $692 if you were to buy it assembled. Hope this helps someone get their project on its feet.
Here is the inside of the case. When I got it the previous owner had broken 3 of the case screws off in the holes. I was able to get them out but scratched up the case on the inside a bit. This will not affect how it works and none of them show on the outside. I found some smaller screws locally that work fine to hold the case ends on.
Your a hero man. Heck of a deal for someone!
I spy a pistol caliber AR
Interested!
Sent from my SM-J727T1 using Tapatalk
Do you still have the ECU
Starting offer $200
E85 fueled, Eaton m112 supercharged 4.5L M62TU, TTV racing flywheel, Spec stage 2+ clutch, 88c thermostat, eibach sway bars, wavetrac 3.15 lsd, m5 steering box, Quantum 340lph fuel pump, Dinan camber plates, some powerflex bushings, Supersprint headers, M5 cats, 2001 gas pedal upgrade and many other things done. all diy by me
