Results 1 to 7 of 7
Thread: very slow coolant leak
    Jan 2013
    Pittsburgh, Pa.
    2001 BMW 330ci
    my '01 330ci has a small leak where the expansion tank fits into the brace. Doesn't leak when system is hot, or several hours after. But in the morning i usually can see a wet spot directly under. I replaced the expansion tank about a year ago when I got the dreaded crack down the side. Is it just not fitting perfectly or is there a washer or o-ring in there somewhere that may be bad. Any suggestions would be appreciated
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    It sounds like you installed aftermarket cooling system parts. That’s strictly verboten! At that mileage and age the cooling system needs to be overhauled. This includes:
    - water pump (Scaleri or Graf)
    - thermostat (Whaler)
    - upper and lower hoses (continental or dealer)
    - radiator (Nissen or Behr)
    - lower hose temperature sensor o-ring
    - expansion tank (Modine)
    - expansion tank cap
    - expansion tank bracket (factory)
    - block drain plug o-ring(dealer)
    - BMW coolant
    - distilled water (AND ONLY DISTILLED WATER)
    Go to www.realoem.com and enter the last 7 characters of the car’s VIN. Hit enter and bookmark the page. I buy parts from fcpeuro.
    Jan 2013
    Pittsburgh, Pa.
    2001 BMW 330ci
    Quote Originally Posted by MarcoZandrini View Post
    - BMW coolant
    Thanks. Pretty sure I got the tank at a dealer, but you are right about doing an upgrade... just putting it off, which i know better. Always great advice from you...Thanks again!
    Jan 2013
    Pittsburgh, Pa.
    2001 BMW 330ci
    Quote Originally Posted by randyg View Post
    By the way, Modine? never heard of it???
    Apr 2018
    South Carolina
    2006 325ci
    - BMW coolant
    Awesome detailed response
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    It’s actually a German company that supplies/supplied parts to BMW. Two bits of advice:
    1. Do not overfill the expansion tank. When cold the top of the red float should be just above the top of the tank’s rim. I know what the owner’s manual sez, but reputable techs have noted here and at E46Fanatics that overfilling the tank is the #1 cause of tank cracking.
    2. Buy a 1.4 bar (~19psi) cap for the tank. This is the cap used on the E30 expansion tank. The M54 cap is 2.0 bar (~29psi). I used a 1.4 bar cap for years on my E46.
    Jan 2013
    Pittsburgh, Pa.
    2001 BMW 330ci
    Great advice. Thx. It's what makes this forum so special! found the moline tank at the FCP link you included.
  1. Very slow coolant leak at Thermostat - Wahler - 2 yr old
    By saneesh8 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 05-13-2015, 03:41 PM
  2. Very Slow Coolant Leak
    By computerwhiz1 in forum 1999 - 2006 (E46)
    Last Post: 10-01-2012, 02:09 AM
  3. very slow coolant leak
    By Bucky540m in forum 1996 - 2003 (E39)
    Last Post: 05-11-2009, 06:20 PM
  4. Anyone else have a very slow oil leak?
    By GENE328is in forum 1991 - 1999 (E36)
    Last Post: 04-10-2006, 07:11 PM
  5. very slow oil leak - should I be worried?
    By virtualj in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-29-2002, 06:54 PM
