Results 1 to 10 of 10
Thread: Front light removal
    May 2018
    UK
    Front light removal
    Ok guys how on earth do you remove the front indicators, ive already had the headlights out and still couldnt get the buggers out.??
    Also the exterior door trims, how do they come off.??
    Jul 2012
    South Yarmouth MA
    11/87 735i & 735il P/C
    I think there's just one screw. Maybe 2:Turn1.jpg
    1983 4-spd Mercedes 240d w/403k - Sold!
    11/87 E32 735iA w/45k - Daily Driver (finally!)
    04/88 E32 735iL - Parts Car
    May 2018
    UK
    Thanks I’m sure I did those two, in picture one on the left there is a square plastic part with a push clip in the middle,what’s it for.??
    Mar 2016
    Lincoln, NE
    91 735iL
    Should be only one bolt and pull it out. I want to say 8mm or 10mm if I remember correctly. Here is a picture of the backside so you can see where it bolts up. Kinda awkward to get to the bolts but not terrible! s-l1600.jpg
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Melbourne, Australia
    '88 750iL, '01 530iT
    2 bolts attach the front indicators to the headlights.
    1 nut on the threaded bit holds it against a bracket on the inside of the front wing. Don't over-tighten it when installing because it'll distort the panel from within. Once this nut is removed, the indicator should slide forward with some persuasion.
    I removed and replaced the indicators and headlights as once piece and then detached them from the headlights once they were out of the car. Easier on my back that way!
    1988 E32 BMW 750iL Bronzitbeige "....4372381"
    2001 E39 BMW 530i Sport touring Cosmosschwarz "....GL80561"
    May 2018
    UK
    Thanks guys, I hadn’t seen the nut so that was the issue.��
    Now then what about the external door trims, how do they come off.??
    Jan 2005
    Japan
    May 2018
    UK
    Quote Originally Posted by shogun View Post
    Sorry for being thick but I can’t see it.
    I’m talking about the external door mouldings.
    Jan 2005
    Japan
    Nothing in the workshop manual? Then check in realoem the drawings, there you can see where there is a bolted area and where clips http://www.realoem.com/bmw/enUS/show...diagId=51_0763
    http://www.realoem.com/bmw/enUS/show...diagId=51_0764
    in this fender replacement DIY you see also some pics of mouldings removal, scroll down here http://bmwe32.masscom.net/sean750/fr...rontfender.htm
  1. 740i front seat removal airbag light
    By ez64 in forum 1995 - 2001 (E38)
    Last Post: 08-06-2010, 08:27 AM
  2. rear light removal (TI) help, please
    By Filip75 in forum 1991 - 1999 (E36)
    Last Post: 05-24-2002, 05:49 PM
  3. F.S. OEM Exhaust/front lights/complete lens set
    By BMWManiac in forum BMW Parts For Sale
    Last Post: 04-25-2002, 10:00 PM
  4. fog light removal
    By InfernoM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-05-2002, 08:51 PM
  5. Fog light removal- how to
    By ScottDetroit in forum 1992 - 1999 M3 (E36)
    Last Post: 07-31-2001, 01:46 PM
