Results 1 to 7 of 7
Thread: Replacing 2001 M Sport Steering Wheel with a 2002/2003 Updated Skinny M Sport Wheel?
    Jun 2017
    Chicago
    2003 BMW 530i M Sport
    So can I just drop in a newer wheel or?
    I would be replacing this wheel:
    With this one:
    I think I would need a new air bag as well, correct? How do I make this happen?
    Pelican Parts's Avatar
    Pelican Parts is offline Senior Member Supporting Vendor
    Aug 2013
    Harbor City, CA
    '02 E39 Touring
    Hello - take a look at the link below to an earlier thread where this is discussed.
    https://www.bimmerforums.com/forum/s...Steering-Wheel
    888.280.7799 | 6am - 5pm PST
    Apr 2018
    Socal
    00 528i, 01 540i
    Yes it will drop in, If you get a complete wheel with airbag then all your have to do is plug and play. Also disconnect the battery first so you won't get an airbag light. There's 2 T30 screws holding the airbag on, on each side of the back of the steering wheel, and the 16mm bolt for the steering wheel itself. The new one you just tighten the 16mm bolt and then reconnect the airbag wires and push it back into the spring holding it on that's on a bracket in the steering wheel. No torx this time. Align the notch on the steering wheel and the steering column to make sure the steering wheel is on straight. I can post pictures if you need.
    (northeast) Indiana
    15 650ix GC & 14 X5 50i
    Just an FYI in case you didn't know...the sport steering wheels with the round air bag (like in the 2nd pic you posted) are under the TAKATA airbag recall. The 3 spoke steering wheel with the triangular air bag (like in your 1st pic) are NOT under the recall.
    Apr 2018
    Socal
    00 528i, 01 540i
    How would one check for the recall? I have the trispoke steering wheel out of a 03 e46 in my 01 e39. I don't know the VIN of the car it came out off.
    (northeast) Indiana
    Since a 2003 3 series would fall between the 2002-2006 build date range...I would say that the one you took from a 2003 e46 would have the Takata airbag inflator that falls under the recall.
    But would BMW contact you? Probably not, because it has no way of knowing that you replaced your steering wheel (with a perfectly functioning airbag inflator) with one that is under recall from a different model/model year that wasn't offered at the time your car was built. Plus the steering wheel was never installed by them (BMW) in your car...but rather was self installed. Would they be on the hook to replace it? :
    Perhaps an internet search may pull up discussions of others in the same situation...and if BMW honored the Takata airbag replacement. The Takata air bag recall has been a MUCH discussed topic...so there is a good chance you will find discussions of this type.
    Good luck.
    Apr 2018
    Socal
    00 528i, 01 540i
    My 01 airbag was already replaced at the dealership also due to recall. Oh wells I'll give them a ring and see what happens.
  1. WTB: WTB 2002-2003 E39 530i MT Sport
    By MKIVGuy in forum 5 series & 6 series
    Last Post: 05-21-2016, 08:08 PM
  2. E46 2001 Multi-function Sports Steering Wheel
    By genuity in forum Interior Lighting & Body Parts
    Last Post: 02-09-2011, 05:42 PM
  3. 2001 BMW 540i SPORT STEERING WHEEL
    By bxdinster in forum Interior Lighting & Body Parts
    Last Post: 10-01-2010, 05:14 PM
  4. 3 spoke sport steering wheel/airbag from 2001 740i
    By kapone in forum Exterior Lighting & Body Parts
    Last Post: 11-30-2009, 02:49 PM
  5. 2001 sport steering wheel FS
    By 2DYE4 in forum 1995 - 2001 (E38)
    Last Post: 10-30-2008, 06:06 PM
