Results 1 to 15 of 15
Thread: Window Switch Cluster LED Upgrade
    Oct 2005
    Maryland, USA
    1989 BMW 535i/5spd Swao
    I wanted to brighten up the dim illumination of the original LEDs in the switch so I soldered in new LEDs.
    NEW 4 of 3MM Amber LEDs with clear lens. 1.8-2.2V, 30mA
    I also took the opportunity to clean the switches and add some grease to the rear window lock button. So the switches move nicely again.
    Images of NEW LEDs:
    OLD LEDs:
    I guess the rear window switch on the door should get fixed next...
    Bruno
    02/1989 BMW 535i M30B35 5spd Converted
    01/2012 BMW 535I N55N30 6spd
    moroza's Avatar
    moroza is offline MORΩN ΛABIA BMW CCA Member
    BFE
    E34T
    Cool! Are the bulbs the same size in the rear window switches? Of those, I've seen probably about 150, of which 3 actually illuminated. I didn't know they were even supposed to light up until seeing it in the wiring diagrams. Never seen burned-out bulbs in the center switch block.
    Oct 2005
    Maryland, USA
    The rear window switches use a regular bulb ( which is usually burned out by now ) , i'll have to solder in a resister and LED set up for those.
    Bruno
    Mar 2017
    STL
    2017 M3 6sp
    Quote Originally Posted by SniperC4007 View Post
    Why resistor? To lower voltage? I can't quickly find now, but I remember replacing all bulbs with LEDs in Audi UrS4 and those were 12V leds so it was pretty much direct replacement
    Mar 2005
    Long Beach, CA
    93BMW 525i/95 BMW 540i/6
    Nice touch.
    USC Ralph - Long Beach, CA USA
    1989 E34 White 525i (M20) 310,000m (Sold)
    1993 E34 Black 525i (M50) 308,955m
    1995 E34 Calypso Red 540i/6 (M60) 201,254m
    1993 E34 Black 525iT (M50) 138,500m
    Oct 2005
    Maryland, USA
    Night time photo:
    Bruno
    May 2017
    Australia
    1989 535i
    Looks great! A guide would be pretty cool if you could make one. How bright are they compared to the original lights?
    As for the rear switches, I didn't know for a long time that they were ever meant to light up. Since finding out I'd love to replace the bulbs but I'm not sure how to even get the switches out. Or what bulbs it uses.
    Denver, CO
    Very cool.
    Guess i always figured they were tiny incandescent bulbs like just about any around the rest of the car. Ill have to break out the bulk leds again soon!
    Maybe one day even start the ambient lighting project.
    Oct 2005
    Maryland, USA
    Did the rear window switches. They are a pain to do, so little space and most of it is used for the rocking motion of the switch.
    I tilted the led to point a little more towards the DOWN arrow so it doesn't look as dim, due to the outline shape vs the solid arrow.
    Bruno
    May 2018
    Croatia
    1995 BMW E34 525TDS
    Were the LED's originally there or?
    Oct 2005
    Maryland, USA
    From what I have seen, the front window switch cluster used LEDs from the factory. The older ones I have opened used orange lens LEDs, and some later ones used clear lens LED that illuminated orange.
    The rear window switches used an incandescent bulb, which is usually burned out by now.
    Bruno
    Jul 2016
    Brandon
    92 M5
    So I was reading through this and got me thinking about my own switches. I found light bulbs for this and then put one in. Can anyone explain to me why the bulbs for these stay lit up no matter what, can on or off. The only way they turned off was when I put the lock on the rear windows from the main switches. I need to check my wiring and see if this is always powered. Explains why they are always burnt out then. My guess is that it was designed so that they are only powered when someone is in back.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Light at the rear switches goes out when you set the button at the main switch in center console to child lock for rear windows. Then the rear windows are also not working.
    Jul 2016
    Brandon
    92 M5
    Quote Originally Posted by shogun View Post
    This explains many things and adds up to what I was finding today while doing it. The lights at the back window switches would be powered no matter what and always taking a slight draw from the battery. Glad I found this out. Now to work on my soldering skills so I can replace the lights.
    Jan 2005
    Japan
    Replace the lights at the rear windows with normal bulbs = original, otherwise the child lock system for the rear windows might be confused when you use LEDs. Because the GM is checking that if lights are on/off.
    When we made the one touch window up/down module, we first had some problems that the rear windows did not work with the one touch function. Then we found out that this was always when the bulbs in the switches were dead or when someone had installed LED instead of normal bulbs.
  1. E34 FS: Window Switch Cluster
    By 89vert507 in forum E34 Classifieds (closing soon)
    Last Post: 06-06-2013, 10:15 PM
  2. Anyone have a window-switch cluster fs?
    By TouringDan in forum 1988 - 1996 (E34)
    Last Post: 08-23-2007, 02:33 AM
  3. Blue LED window switches
    By RahgBag in forum Exterior Lighting & Body Parts
    Last Post: 03-17-2007, 10:41 AM
  4. Window switch LED conversion DIY tutorial
    By bbohica in forum 1991 - 1999 (E36)
    Last Post: 03-02-2007, 10:46 AM
  5. Replies: 6
    Last Post: 06-26-2004, 04:39 AM
